Xantia sump plug size
Whats the size on these plugs, is it 21mm or do you need some stupid service tool to poke in the hole in the middle?
My DT has been fitted with a 1.9 Xantia engine, the sumps got two plugs one at the front (high) and one at the rear of the sump.
Is there a trick to getting all the oil out, cos it looks like a fair amount will stay at the lower front of the sump.
It should be 21mm I think and just undone the rear 1 on the sump.
(12-01-2013, 10:19 AM)r3k1355 Wrote: Whats the size on these plugs, is it 21mm or do you need some stupid service tool to poke in the hole in the middle?
Make sure you take the filler cap out the top of the engine and run it for 5mins before to warm the oil up.
21mm spanner or 8mm allen key
  Sump plug thread Dazecoop 1 953 04-01-2016, 04:54 PM
Last Post: welshpug
  Top mount intercooler bolt size/ timing hole size LewisG306 2 1,932 13-07-2014, 10:44 AM
Last Post: LewisG306
