11-01-2013, 03:08 PM
As title really anyone in the Midlands area known to give good stage 1 for a hdi?
Midlands area stage 1 mappers.
11-01-2013, 03:18 PM
Buy yourself a KWP2000+ for £20 and buy a map off someone on here, then do it yourself. Save £££ and have the luxury of being able to redo your car whenever you please.
11-01-2013, 03:58 PM
the main reason being my history with technology would mean i'd probably turn the engine into a bread roll.
11-01-2013, 04:17 PM
whats that then? KWP?
11-01-2013, 05:40 PM
Mr whippet is only in Leeds. Took me about a hour from j26 m1.
45 minutes on way back
17-01-2013, 05:49 PM
I went to pro steve coming from birmingham took me just over an hr
21-01-2013, 01:12 PM
(11-01-2013, 03:18 PM)silverzx Wrote: Buy yourself a KWP2000+ for £20 and buy a map off someone on here, then do it yourself. Save £££ and have the luxury of being able to redo your car whenever you please. Yes you can but be very carefull as i bricked an ecu with a Galletto, maybe the kp's diffirent or better but i wont do it again
21-01-2013, 01:17 PM
Done it loads of times and never bricked an ECU, just got to follow the instructions. The key is having a decent laptop and not touching anything while it's writing.
21-01-2013, 01:51 PM
I know and i did that.....and didnt tiuch anything but stopped half way through the write and fkd it
21-01-2013, 02:11 PM
Cheers for the responses folks, ive been having a chat with Mr Whippet about maps.
21-01-2013, 02:22 PM
(21-01-2013, 01:12 PM)stu9 Wrote:(11-01-2013, 03:18 PM)silverzx Wrote: Buy yourself a KWP2000+ for £20 and buy a map off someone on here, then do it yourself. Save £££ and have the luxury of being able to redo your car whenever you please. I've done 5 or 6 remaps now on different cars with a Galletto and a crap old Acer laptop, really is just bad luck if you brick an ECU.
01-02-2013, 08:09 AM
If you still need a remap, I can make one for you.
Ask DumDum or Pipps how my maps are, they both run them. (and probably a lot of other members as well)
01-02-2013, 02:48 PM
How much do you charge for a stage 1? And what power do you state?
01-02-2013, 04:00 PM
Mine's running a map by tb and I'd highly recommend his services........
03-02-2013, 08:35 PM
(01-02-2013, 02:48 PM)Kezzieboy Wrote: How much do you charge for a stage 1? And what power do you state? Stage 1 is up to 130BHp tops. 130 requires every single bit in the engine is perfect, so expect 125bhp. Torque is 280NM. Stage2 is up to 160BHp 360Nm Stage2+ is 160BHp 390Nm ...Beyond that, it depends on the hardware used, but up to 210Bhp and 450nm relatively easy. More than this and it gets expensive.
03-02-2013, 08:59 PM
(03-02-2013, 08:35 PM)tb205gti Wrote:(01-02-2013, 02:48 PM)Kezzieboy Wrote: How much do you charge for a stage 1? And what power do you state? Tb how do I get in contact with you mate? Im gonna be requiring a stage 2 in the very near future and your pm has been disabled
04-02-2013, 08:03 AM
My PM should work by now. Apparently you need at least 10 posts before the PM system is activated
04-02-2013, 09:27 AM
Tb map ftmfw
04-02-2013, 10:45 PM
How many monies dude?
06-02-2013, 05:51 PM
07-02-2013, 04:06 PM
anyone in the suffolk area good at mapping or able to upload a map for me?
08-02-2013, 04:56 PM
I can do a stg1 file for £75, or stg2 file for £100, along with support (ie, if you brick the ECU etc)
Thanks Dave |
