intercooler
what do you think of this intercooler on a xud http://www.ebay.co.uk/itm/190451381581?s...1439.l2649
Perfectly fine. I have a similar one on mine
im going for a slightly bigger one
http://www.ebay.co.uk/itm/UNIVERSAL-INTE...20ba29085d
That cooler will be fine. You dont need amything massive.
Not having a go. Just a point in the right direction.
This section (newbies) is just to say hi and introduce your self. There are dedicated sections for questions like this where you will get a better response. You not restricted to this section because your new Big Grin.
For example this thread would be better in the "XUD" section. Hope this helps
Moved to the correct section
[Image: kim.png]
thanks.
As above, that cooler is fine. I have a bigger blower too and it's perfectly adequate.
Good choice, sure these eBay jobbies are at least 3x the thickness of the TMIC so should be more then enough!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
what size inlet/outlet ports ye chaps recommend?
