GT2560LS Too Big?
GT2560LS Too Big?
Doing a bit of research and was wondering if a 2560LS would be a tad too big for the DT?
Just wondering as they can be picked up pretty cheap and should be easy to fit with there exhaust hosing design.
[Image: sig.jpg]
What's it off?
Depends totally on the A/R - technically that should be a good turbo, but as said earlier, depends what it's off, if it's off a 7.0l Diesel or a 300hp petrol, it'll be useless, the A/R will be massive, it'll just lag and lag until it finally gets going, then be 2 seconds of awesome and the pump will run out of puff....
I've tried to find the a/r but with no luck, some more rersearching will be needed, its from a mk1 frs 210bhp 2.0 turbo petrol, but there good for 3/330 in there original aplication.
I'm realisticly looking for ~180bhp with a quickish spool but still good for 5.5-6krpm also been considering a 52 or 56s in 20 or 22 frames also.
[Image: sig.jpg]
Why do you need 5.5-6k rpm? A bit pointless if you'll make 180 with good spool/ midrange on a gt2052/56.
Check out the compressor maps and do some calcs to double check.
[Image: brokendown-1-1-1.jpg]
Dturbo GT2259s build thread;
I don't, just a longer powerband would be nice if it was avalible.
[Image: sig.jpg]
You've got to consider the powerband below that, it'd end up that it starts at 3k and then goes to 6k - where from 4k the Bosch VE is tapering it's fuel down... When you could have made it that you'd have 95% of that power from 2k until 5.5k - with less strain on the engine, injection pump blah...
If anything I'd say it's a bit big, you can get a GT2056S which is literally perfect for these engines for around the same price and the power would be SO much better...
Unless you had a pump test rig, knew exactly what you were doing to make the pump fuel reliably until 6k, not bog out etc, then go for the 2560LS - but otherwise, you'd make 95% of the power with a 2056S and with a quarter of the ballache of making it rev to 6k...
My 2052V will do pretty much 200hp, take 10-15hp off that as it's a WG turbo and add 500rpm onto the spool... 2056 should do 220-230 if you can hold things together and make the pump provide the fuel without stupid EGTs... If you're going for a 56mm and going for crazy power, you'd probably be better off with a GT22 frame, keep your EGTs and EMPs down. Obviously the 2056S is better for midrange power, it can shift a massive quantity midrange, but you'd find you'll need to keep the boost down, or you'll cook things.
From the Dyno on my car, it's peak power was at 4400rpm, that's only a "baby" 2052v... You'd probably find that was the pump dying off in actuality!
Lots of info there Ruan.
What sort of rpm does yours spool at?
Ideally would like usable boost from 2k, with peak coming in around 2.5k maybe?
I'm thinking a 52 would spool up say 300 rpm earlier than a 56 but not give you as much flow getting onto the 5k range, raising the EGT and EMP higher up the rev range.
Ideally I'm looking at keeping south of the 200 mark retaining a 9mm pump.
[Image: sig.jpg]
Mine spools so quickly it surges before it gets going... If the head flowed it and you set the start screw in enough, you could shove 20lbs down the inlet at 1700rpm... But the head simply won't let it through so it just surges... Essentially you've got full power from about 2400rpm with the head as standard, but I even have to keep it from producing too much torque down there with the throttle, or I just end up slipping the clutch or stretching the head studs... About 3k it's fully into it's stride, it'll go until 4800 and you do feel it die past there, but it's more the pump than the turbo, the boost never drops until the fuel does.
If you're looking for sort of 170-180, 9mm.. GT2052S for certain... Stupidly quick spool for it's size, I'd say you'd have full torque from about 2600rpm, holding the power 'till 5k....
I've always said GT2052S or GT2056S is perfect for these engines...
Gonna be looking at one of the 52s off a 2.2 diesel. Would be really easy to fit too.
Cant find the a/r for it but have the dimensions of the turbine exd and ind, and the compressor exd cant find the ind anywhere. They are 40, 47, 52.2 respectively
I've also got one of the Iveco Ko3's hdi power has fitted on his hdi. Looking at it compared to the 52s spec wise it looks a good size although a tad smaller.
Got some details on it and was wondering if you think it would be suitable.
Turbine; ind 45, exd 40.33 trim 80.32 - Comp; ind 37.8, exd 51 trim 54.93
Again cant find the a/r for it.
Would be ideal if I can use it as it would save me a bunch of cash.
[Image: sig.jpg]
Ruan Wrote:Mine spools so quickly it surges before it gets going... If the head flowed it and you set the start screw in enough, you could shove 20lbs down the inlet at 1700rpm... But the head simply won't let it through so it just surges... Essentially you've got full power from about 2400rpm with the head as standard, but I even have to keep it from producing too much torque down there with the throttle, or I just end up slipping the clutch or stretching the head studs... About 3k it's fully into it's stride, it'll go until 4800 and you do feel it die past there, but it's more the pump than the turbo, the boost never drops until the fuel does.
Yeh you've always had a wierd pump ruan... govmodded to f*ck, and just dosent rev out... you need some rpm in your life Wink
My 11mm pump (sam barkers old one built by darren) used to happily rev/pull to over 6k even with a tiny ko3
[Image: sig.jpg]
Yeah, my pumps always been a wierd one, worked perfectly, but stops at 5500rpm...
(26-04-2012, 02:11 PM)Chris Wrote: I've tried to find the a/r but with no luck.
doing turbo research for the 205, A/R for this turbo is 0.52 whether it's any use for you now at all.
Quick specs for my blower for you..
GT2056S
270degree journal bearing
Compressor wheel 56mm, 55 trim
Compressor A/R .53
Oh and it flies when it works. Admittedly the last one had chronic boost through it but it was insane, plant your foot at 30mph in 3rd and the wheels just lit up lol camber and poor tracking don't help but it torques up very quickly.
One day thinking of stealing a 60mm coldside from a 2260 but need to get this working right first. Also have concerns over pressure ratios with the 60 given that the 56 seems to like snapping shafts at high-20's psi.
I nearly bought a 2560 from a RS for the 2.1....but the maps show its just not efficient enough for the size until the engine really gets going....and it really gets going in the RS at 4000rpm!!!
(06-01-2013, 05:04 PM)Piggy1987 Wrote: I nearly bought a 2560 from a RS for the 2.1....but the maps show its just not efficient enough for the size until the engine really gets going....and it really gets going in the RS at 4000rpm!!!
Didn't know compressor maps showed you that!
what engines were the 2052s fitted too? after a search all i could come up with was some mg/rover 1.8t petrols...
(06-01-2013, 06:42 PM)sweeney1987 Wrote: what engines were the 2052s fitted too? after a search all i could come up with was some mg/rover 1.8t petrols...
Just from the top of my head, excluding trucks/vans
AUDI A4 TDI
AUDI A4 TDI
AUDI A4 TDI
AUDI A4 TDI
AUDI A4 TDI
AUDI A4 TDI
AUDI A4 TDI - 155HP
AUDI A4 TDI - 163HP
AUDI A4 TDI Quattro - 180HP
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI
AUDI A6 TDI - 150HP
AUDI A6 TDI - Quattro - 180HP
AUDI A8 TDI
AUDI A8 TDI
AUDI A8 TDI
AUDI All Road
AUDI All Road
AUDI Allroad - 180HP
AUSTIN ROVER 75
BMW 525 D
BMW 525d - 163HP
LANCIA THESIS
LANDROVER DEFENDER
LANDROVER DEFENDER
LANDROVER DEFENDER
LANDROVER DEFENDER Td5
LANDROVER Defender Td5
LANDROVER DISCOVERY
LANDROVER DISCOVERY
LANDROVER DISCOVERY
LANDROVER DISCOVERY Td5
LANDROVER Discovery Td5
MERCEDES C220
MERCEDES C220
MERCEDES C220
MERCEDES C220 - 125HP
MERCEDES C220 CDI
MERCEDES C220 CDI
MERCEDES C220 CDI
MERCEDES E220
MERCEDES E220 - 125HP
MG R75
MG ZT Turbo
NISSAN Cabstar - 125HP
NISSAN FRONTIER
NISSAN FRONTIER
NISSAN MISTRAL
NISSAN MISTRAL
NISSAN PATROL
NISSAN PATROL
NISSAN PATROL
NISSAN PATROL
NISSAN PATROL
NISSAN Patrol - 160HP
NISSAN Patrol Di
NISSAN Terrano II
NISSAN Terrano II
NISSAN Terrano II
NISSAN TERRANO II
NISSAN TERRANO II
NISSAN TERRANO II
ROVER 75 T
ROVER MG R75
ROVER MG ZT
SKODA SUPERB TDI
SKODA SUPERB TDI
SKODA SUPERB TDI
SKODA SUPERB TDI
SKODA SUPERB TDI
SKODA SUPERB TDI
SKODA Superb V6 TDI - 155HP
VOLKSWAGEN LT II
VOLKSWAGEN LT II
VOLKSWAGEN LT II
VOLKSWAGEN LT-28/35 II Van
VOLKSWAGEN PASSAT TDI
VOLKSWAGEN Passat TDI - 150HP
VOLKSWAGEN Passat TDI - 180HP
VOLKSWAGEN T4 Bus
VOLKSWAGEN T4 BUS
VOLKSWAGEN T4 BUS
VOLKSWAGEN T4 BUS
VOLKSWAGEN T4 BUS
VOLKSWAGEN T5 Transporter
VOLVO S60
VOLVO S60
VOLVO S60
VOLVO S80
VOLVO S80
VOLVO S80
VOLVO S80
VOLVO V70
VOLVO V70
VOLVO V70
VOLVO V70
VOLVO V70
VOLVO V70
VOLVO V70 D5
VOLVO XC 70 D5
VOLVO XC90
VOLVO XC90 D5
NISSAN TL18
NISSAN TL18
Nissan Diesel TL18 Light Truck
and the 2052's'
LANDROVER DEFENDER
LANDROVER DEFENDER
LANDROVER DEFENDER
LANDROVER DISCOVERY
LANDROVER DISCOVERY
LANDROVER DISCOVERY
MERCEDES C220
MERCEDES C220
MERCEDES C220
MERCEDES C220 CDI
MERCEDES C220 CDI
MERCEDES C220 CDI
MERCEDES E220
NISSAN FRONTIER
NISSAN FRONTIER
NISSAN Terrano II
NISSAN TL18
NISSAN TL18
are a lot of them not vnt though? im thinking non vnt...
(06-01-2013, 06:47 PM)sweeney1987 Wrote: are a lot of them not vnt though? im thinking non vnt...
it seems the landrovers have a wide variety of 2052's non vnt
My 2052 is not a VNT
GT2052s DTurbo
OEM+ HDI Estate
Project thread
2 thoughts, one post...
the map shows to me it needs more higher revving to make it efficient and as an EXAMPLE the RS really gets on boost at 4000rpm
(06-01-2013, 07:38 PM)Ricky Wrote: My 2052 is not a VNT
after 2months I still cant find either a 2052 or 2056 that isnt VNT!
Its not quite that simple! I suggest you do some more reading. A good start point is garretts own website. although a 2560 is taking the pisscuit on an xud imo.
And if you honestly can't find one, you're not searching properly/hard enough. Should be a few knocking about, but I suspect it being a case of budget? In which case it will help you to know which vehicles have your turbo, and search them up instead.
(06-01-2013, 10:08 PM)Piggy1987 Wrote: after 2months I still cant find either a 2052 or 2056 that isnt VNT!
There's loads at a reasonable price on ebay right now.
What he said! I had a quick browse earlier and found a few for around 100quid mark Big Grin
100???? want to be getting one for less than half that!! Tongue
^^^^^yeah amen....dont mind paying close to that for a good one....but couldnt find any NON vnts....I am more in hunt for 1752 anyhow, 1)more available 2) the 2.1 is a lazy torque muncher and the 1752 seems to be what I need for that
(07-01-2013, 07:49 AM)Piggy1987 Wrote: ^^^^^yeah amen....dont mind paying close to that for a good one....but couldnt find any NON vnts....I am more in hunt for 1752 anyhow, 1)more available 2) the 2.1 is a lazy torque muncher and the 1752 seems to be what I need for that
Mate £100 is a good price for a gt20 if it's in good condition. And the ones I can see are wastegate.
