File Line Function
/global.php 961 eval
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1651 eval
reprogramming two keys help
Hi I have two keys for my 306 roland garos. Recently one stopped working, battery is ok. Went through reprogramming as per manual key now works but other key doesnt. To reprogram the key ,one key must be in ignition and after the process the key in the ignition will not open the doors. Basically reprogram one key the other doesnt work .,so how do you reprogramm two keys. Car is an M reg 1984 and these keys have worked since I bought the car 14 years ago. The key has two plips for entry and imobiliser. Any one else come accross this and how to remedy it Thanks
When you say reprogram, do you mean reprogram for the central locking to work or are you trying to reprogram it to start the car?
Welcome BTW Smile
Sorry if I didnt makeit clear its for central locking
  Programming keys to different BSI allye 8 9,088 26-01-2017, 08:11 PM
Last Post: DeeTurbo
  Reprogramming car keys deggerz 2 2,395 28-07-2014, 10:52 PM
Last Post: deggerz
  everything stays on when keys out DTurboTom 38 18,070 20-01-2014, 09:01 PM
Last Post: nath86
