22-01-2012, 01:39 PM
Is it ok to use 5.1 brake fluid? the cap dose say dot 4 only tho
| The following warnings occurred: | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
5.1 and 4 brake fluid
22-01-2012, 02:19 PM
IIRC only if you have the whole system bled through with 5.1, you cant use a mixture of them.
I usually use 5.1 when i bleed brakes on a 306.
22-01-2012, 02:31 PM
You can use what you like, but just don't mix different dots together, 3 and 4 can mix, but anything else is a big no no
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
22-01-2012, 03:50 PM
Why can't you mix them?
I was told that if it needs DOT 4, then anything DOT 4 and above would be fine....as it'll just have a higher boiling point.
22-01-2012, 03:53 PM
Because they can react to each other... Should have been thought that at college
22-01-2012, 03:56 PM
Connor Wrote:Because they can react to each other... Should have been thought that at college Ah didn't know that, cheers. What happens if they do react? Air bubbles I guess?BTW, you'd be surprised what we aren't taught in college! hock:
22-01-2012, 03:58 PM
Well its like water and oil, they don't mix... same thing for brake fluid, dot4 is a different liquid to dot5.1
22-01-2012, 04:05 PM
Oh, fair enough.
22-01-2012, 04:12 PM
And I wouldn't be surprised at what they don't teach you, any time we had to go into the workshop at college, we always had to fix all the full time students f*ck ups...
22-01-2012, 06:13 PM
Isnt it something to do with semi synthetic and fully synthetic or am i going nuts again?
22-01-2012, 06:18 PM
Connor Wrote:And I wouldn't be surprised at what they don't teach you, any time we had to go into the workshop at college, we always had to fix all the full time students f*ck ups... Lol, we spend a lot of the time fixing the school kids/level 1's muck ups (whats up with the swear filter!?).......they treat the cars there like shit tbh, wouldn't wanna let them loose near my car!! |
| Best brake fluid and pads? | JTaylor2005 | 19 | 10,653 |
19-08-2016, 08:09 PM Last Post: Pgtips |
| ATE v Pagid dot 4 brake fluid | 306rhys | 1 | 3,039 |
28-08-2015, 10:08 AM Last Post: PartyJas |
| Brake fluid circulation | hennus | 5 | 3,653 |
12-03-2015, 10:49 PM Last Post: Niall |
