Soooo I made me a mistake!
Just found a site known only as "VAG Explorer" I'm not going to mention how I clicked on the link but it's a nifty little tool for VAG vehicles, tells you all the options it came with this is what mine came up as:
Product Name: Polo 37 EU2 5G
Sale Type: 6N10H4
Assembly Plant: Navarra - Pamplona - Spain
Release Date Factory: 15/07/1999
Year Model: 1999
Engine Type: AER > SR 999cc - MPI - 37kw ( 50hp)
Box Type: EQW
Color Code: J2> chagall blue / blue tukan ( LD5D )
Equipment (Numbers PR):
1E1 Reservoir has charcoal
6EA Without additional coatings on body dimensions (rockfall)
3B0 Without additional anchors for child seat-
2WA Without additional tires
4UE Airbag for the driver and passenger seats
7AA Electronic immobilizer
1C1 Freeze until -25 degrees Celsius -30 degrees C until tolerance
3H3 Unlocking the folder or front seats
T3M 4-cylinder gasoline engine 1.0 L Engine 030.L (aluminum)
J0A Betterie 175 A (36 Ah)
5C0 Without particular measure for body
K8G Hatchback
1LB Disc brakes at the front
1KH Drum brakes at the rear
1AL Booster
4L2 Mirror inside security-adjust day / night
2JF Painted bumpers
7QA Without CD / DVD for navigation
7A0 Without CD changer / CD player
5D0 Without carrier frequency
4W0 Homeless for cassettes / CD
8R0 Without center high-mounted stop light
3C1 Static lap belt in the back in the middle
0Y1 Standard climatic zones
1K1 Mechanical clutch
B0N Chipset, version vehicle for Great Britain, various parts
6FA Components without particular area
6Y0 Without warning device Overtake speed
4M0 No cupholders
4N2 Dashboard standard
4F0 Mechanical lock
3LK Side door and coating film in full compact surface without ashtray in the rear
0A1 2 doors
M85 4-cylinder gasoline engine 1.0 L/37 kilowatts MVEG 2 - Base Engine: T3M
A8C Comfort equipment
2B0 Without additional external sound
1T0 Without aid kit, warning triangle without
4Q0 Not readily flammable materials
0TA Without floor mats
2V1 Dust and pollen filter
5VA Without load floor at the front
8WA Without the front fog light
5l0 Without front spoiler
0AA Without a front stabilizer bar
6Z1 Flashing amber
1Z2 Increase in the first series of refueling
0F2 System fuel injection petrol engine
2LB Fuel tank has special treatment of the material
6R3 Barrel shifter rubber
6Q1 Knob / handle shifter plastic
C06 Operating permit, alteration
8GM Alternator 70 A
6PA Handle handbrake plastic
8BF Halogen headlight for driving on the left
8K0 Without special headlight activation
8X0 Without headlight washer system
8Q1 Headlight-range adjustment
7E0 Without heat accumulator / auxiliary heating
9T0 Without heated washer nozzles
9AA Manually controlled heating system
1EX Nameplate for special EC passenger car M1
0RA Without locking system ignition / starter of
2G1 Insert for filling unleaded fuel
U0L Instrument insert with tachometer clock and mph speedometer
8E2 Local interference suppression for FM / reception amradio
8QA Key without LED
3BF Outside Mirror left convex, electrically adjustable and defrosting
3U1 Boot covers, folding
6SE Trim a luggage trunk floor, needle felt
0FB Manufacturing cycle Pamplona
6N0 Without valance fenders
0NB Registration standard finish
7Q0 Navigation device without
3ZB Automatic three-point belts in the rear on the outside with ECE label
5K1 Processing preservation paint (wax)
3CA Free wall (separation cabin or net)
4B1 Baguette Side protection
6KA Calender
8AA Without radio
3GA Without load floor
8TD Rear fog light for driving on the left
3Q0 Without headrest in the rear
3NB Seat / backrest back, folding block
5J1 Spoiler rear
0BA Without stabilizer bar in the rear
3QT Three-point automatic belts tensioners and height adjustment on the front
3AV Mirror right outside, aspheric, electrically adjustable and defrosting
3FK Sunroof / swivel glass with jealousy
3L0 Without adjustment of seat particular
9P0 Without seat belt reminder
N0E Woven fabric seat covering
4A0 Without heated seat
4X0 Without airbag Side
4KA Lateral and rear windows clear glass
8F2 Side turn signal lights
1G6 Spare, compact
8RE 4 speakers (passive)
0UA Particular colors without
E0A No special edition
0SC Stickers / plates in English
8CC Speedometer sensor without seal (electronic speedometer sensor)
1N0 Management standard
L0R Right-hand drive vehicle
1MZ Steering wheel for airbag system
0KA Without sticker or logo
8SA Taillight assemblies, standard design
9W0 W / o car phone preparation / installation
0L0 Mechanical control throttle
H0C Tires 205/60 R16 92V optimized rolling resistance
G0C 5-speed manual transmission
B09 Countries with type approval Great Britain - Northern Ireland
GP0 Vehicles w / o special upgrade Measures
0DH Differentiation of classes of vehicles 6N0
F0A No special purpose vehicle, standard equipment
1NE Central wheel protection
C0A Alloy wheels 8.5J x 17
4R0 Leve-ice mechanics
4GD Windshield clear glass
PE1 Option not currently known in the database
PR1 Option not currently known in the database
Q1W Standard Front seats with integrated storage trays
V0A Tires w / o specification of brand draws
W0S Option not currently known in the database
Still a piece of shit despite all the options.
Member of Team Rather be Gay than Ginger
Member of Team Holey Engine
[Image: IM_sig.jpg]
Got a link to the site?
Did I read that right where it said it comes without a radio!
As requested, the first link is VAG Explorer and then there's also the Options decoder...Now obviously they only work with VAG cars so if it's a Peugeot it's not gunna do anything. Also with the VAG Explorer it came back as my vehicle wasn't on their system and to check back within 24 hours, few hours later and there she was so not a clue how it works!!!
[Image: IM_sig.jpg]
peugeot has the same its called servicebox and is >Here<
(29-12-2012, 10:27 AM)cully Wrote: peugeot has the same its called servicebox and is >Here<
can anyone sign up for it?
Anyone can register, buy its still useless unless you know the part you want
(29-12-2012, 11:41 AM)Daniel306 Wrote: Anyone can register, buy its still useless unless you know the part you want
Well no shit. You wouldnt go on there looking for parts aimlessly would you? lol
