	Threads: 24
		From knowledge of the phase 3 safety features, the thought has occured to me that I might be able to install them in a phase 1 if I get a controller from a phase 3 and get the passenger and side airbags as well. I am not actually planning to do this, far too much hassle for little gain but what would be involved in implementing such?
And perhaps while you are there have some more side impact beams welded to between the door skins as the standard side impact beam is only; well it is just that, a beam, not beams as in plural. Also what could be done to improve front protection? Perhaps some extra bracing to the chassis legs for good measure?
Normally these things need a lot of simulations and tests running to see how certain structures will be affected by the extra rigidity etc and how it would effect the crumple zones, but only a little bit more metal can't hurt, or can it?
Just thinking in terms of plans for the future, might not hurt to update the phase 1's safety features a little bit if it can be implemented for reasonable value. Anyone else got any bright ideas? :roll:
	Threads: 29
		I know a great safety feature.... Slow down.
	Threads: 18
 Car Model/Spec: Phase 1 Sigma Blue 306 Dturbo
		Yeah dont bother sounds to much like hard work would add weight and props affect handling, why change the safty features of a car designed in the early 90's ??
	Threads: 92
 43
		Front end doesnt need strengthening, trust me. 306 1-0 BMW
	Threads: 24
		Anymore details on the above? I am sceptical of a 306 holding up to a BMW, but I would like it to be true.
	Threads: 92
 43
		Well I drove mine home, the BMW wouldnt even start...
	Threads: 24
	Threads: 92
 43
		Wasnt really the first thing on my mind...
	Threads: 18
		I believe you connor
	Threads: 92
 43
		I believe me, its what happened
	Threads: 18
		  yeah taking pictures of a crash is the last thing on ya mind normally
	Threads: 24
		OKAY NOW EVERYONE SOD OFF UNLESS YOU HAVE A CONTRIBUTION TO MAKE.
	Threads: 92
 43
		I have a very valid contribution, no need to get up your own ass...
	Threads: 27
 20
		Ha ha best safety feature is not to crash
	Threads: 24
		Okay we know that genius. But as you can see that is not the point of this thread.
		Flynn there is one safety feature that you have overlooked. Leave the car in the drive! That's the safest way. Airbags are not really going to help you in a crash really. Especially ones in a 12+ year old car that might not even detonate in a crash!
	Threads: 27
 20
		Ok serious answer
Rollcage
	Threads: 18
		i did make a contribution, like i said whats the point in outting all that in your car to much of a faf just leave it be and drive carefully
	Threads: 24
		Jonny b Wrote:Ok serious answer
Rollcage
Well that's an improvement over your previous but still not good enough. A trollcage won't be suitable for me as it would be far too restrictive. Also it would not protect in frontal impacts, if the damage got as far as the rollcage you would already be like a sardine in a tin anyway. What are the implications of reinforcing the front and middle aspects of the car?
		Flynn Wrote:Jonny b Wrote:Ok serious answer
Rollcage
Didn't realise posts had to be good enough. I do apologise for letting you down!
What your talking about then really is strengthening the chassis and that isn't going to be easy or cheap. If it really worries you, get a different car. Unfortunately the 306 isn't the safest car in the world!!
	Threads: 18
		The guy gives you a serious answer and you still winge about it and you wounder why everybody puts silly answers down
	Threads: 27
 20
		Well then either buy a new car one that has a decent ncap rating, or I revert back to my original post of don't crash
	Threads: 34
 8
	Given 8 thank(s) in 8 post(s)
		Lots of foam + cushions? Much easier, or do like clarkson and make a concrete floor, thatll stiffen it up a little bit.. Use it in doors aswell.
Oh and its cheap?
	Threads: 20
 Car Model/Spec: Durbo
	Threads: 27
 20
		Flynn you sit in the car and we will come round and fill it with concrete free of charge!! Safe as houses then bud
	Threads: 24
		Hitchos Wrote:The guy gives you a serious answer and you still winge about it and you wounder why everybody puts silly answers down What so pointing out the downsides as a matter of conversation is 'wingeing' now is it? You are becoming very irritating, very fast.
 Jonny b Wrote:Well then either buy a new car one that has a decent ncap rating, or I revert back to my original post of don't crash
No mate. I am talking about little things like perhaps welding some small pieces of tubular bracing from the bulk head to the inside of the inner wings. Also there have been several threads that show a 306 stands up quite well in real world crash scenarios. The last one protected it's occupant in a head on where he was doing 60 and the other car was doing 80!
	Threads: 20
		Take a look at that video. You are going to have to do some serious work to change the outcome. The video/test is a common test due to it being a fairly common type of crash, and at only 40mph, you have to say, it took rather a beating. Also, the actual driver ratings where pretty poor. The chest area (rather an important area I feel) scored a "Weak", one from the bottom of a 5 rating colour system. Your gonna have to do a lot to change this. - Not "little things".
Matthew
	Threads: 18
		Flynn Wrote:Hitchos Wrote:The guy gives you a serious answer and you still winge about it and you wounder why everybody puts silly answers down  Flynn Wrote:What so pointing out the downsides as a matter of conversation is 'wingeing' now is it? You are becoming very irritating, very fast.
Proberly get a warning for this but:
If yu were such a genious you would have figured out i wasnt just on about this thread but just about every reply you make you are either calling everybody fools or idiots or whatever, people give you advice you disagree with them you are a very opianated person do you talk to people like that when your not behind a computer no i dont expect you do so get off your high horse just look at just about every reply you make you annoy somebody, so who is the irritating one??
	Threads: 163
 53
 Car Model/Spec: 406 HDI
		Tell you what, why don't you have a look at a brand new Focus? Hugely safe, 73 airbags, crumple zones, traction control, massive brakes, deformable dash materials. Then you'd be far safer than in a 306
Also, you could join a Ford forum...
	Threads: 24
		Hitchos Wrote:people give you advice you disagree with them you are a very opianated person
Correct.
 Hitchos Wrote:do you talk to people like that when your not behind a computer no i dont expect you do so get off your high horse just look at just about every reply you make you annoy somebody, so who is the irritating one??
Talk to people like what? My reply to jonny b was perfectly civil, you are just trying to become popular because you've seen it is cool to bash me.
 THE_Liam Wrote:Tell you what, why don't you have a look at a brand new Focus? Hugely safe, 73 airbags, crumple zones, traction control, massive brakes, deformable dash materials. Then you'd be far safer than in a 306
Please read the thread title to see what this thread is about, it is not a 'what car' thread. Besides I don't want to be another drone in a Focus.
