XUD oil feed block thread size
Does anyone happen to know the thread size for the block off the top of their head? I'm trying to get a line sorted for the new blower.
Thanks
Stage 2 XUD Sedan
yup one sec...
m16 x1.5, i put n my project thread as I knew I'd want to know again Wink
Be warned though, the length is odd... Best way is to use a T2 line with a compression fitting half way... Or find a banjo bolt out of a HDi as the length is the same Smile
Any banjo bolt will work using the right thread as the banjo only relies on the copper washers not the seat at the bottom, but that will work just fine Smile
[Image: sigi-2.png]
I can sort a braided line to any spec you want
  What thread is fuel feed for a bosch? silverzx 8 5,288 04-02-2015, 03:51 PM
Last Post: silverzx
  temperature sensor thread size Chris_90 2 2,373 22-09-2014, 04:35 PM
Last Post: Chris_90
  GT2052V & TD04 Oil Feed Thread silverzx 7 5,814 18-07-2014, 05:02 PM
Last Post: Tom
