Caliper sliders
One of my front caliper sliders have seized, do I just need to buy these (link below) or is there something else I need aswell?
CLICKY
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Seized how? Run dry or is it bent? Only ever replaced 1, that I accidentally bent.
If you take it out and clean it up properly you shouldn't need to replace it. I had to use mole grips to get my neighbours sliders out on his Focus as they were solid with rust. Spent half an hour cleaning them up with the dremel, applied the proper grease and job's a good'un.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
Yeah think they are dry and rusty, will try and get them out and clean them up, those slider bolts are quite a lot of money really..
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Once you have it out, if there's lots of dry flaky rust you might need to get a screwdriver in there and drag it out, or apply a little grease to the end and dab it in there to collect the rust.
My neighbours were absolutely terrible, but worked fine after i'd spend a couple of hours sorting them.
Sorry to jack the thread but where the best place to get new boots for them as mine have ripped? Is it just straight to dealer?
(10-12-2012, 01:30 PM)PE02KHG Wrote: Sorry to jack the thread but where the best place to get new boots for them as mine have ripped? Is it just straight to dealer?
try here http://www.biggred.co.uk/catalogue.php
thank you
Just what I was about to suggest Smile
Uno momento; it took me ages to find the right slider (gti calipers?)
I've got a massive thread somehwere, one sec
uodated here
http://306oc.co.uk/forum/thread-2784.html
original thread here http://www.theywhoshallnotbenamed/forum/...der-Damper
  Rubber Seals around the sliders on bendrix rear brakes mattbarker32 3 2,321 11-09-2015, 07:25 PM
Last Post: mattbarker32
  Caliper sliders DeeTurbo 19 11,621 08-03-2013, 07:52 PM
Last Post: DeeTurbo
  Rear Caliper sliders Daniel306 5 17,077 30-01-2012, 05:31 AM
Last Post: gareth7
