A very long winded project this one, some of you know it as I've had the car around 7 years now buying off a mate from London with a dead bottom end to replace my old 309 Race car
I'll add a proper description as I go along but some pic's to start with
First off how it started with a fully stripped car and mild spec engine, Steel Rods, JE Piston's, Head and some Kent cams with mere pin hole 45mm bodies
Then
Much better and allot Lighter being 50's
Engine on the stand, new spec is basically
Sanex Rods
JE Pistons
Mad Pete Head with larger inlets and flowed nicely (I hope)
Solid Lifters with Cat cams 4903272 with a huge 13.75 lift
Extra Long Inlet manfold
Renault Pico Injectors
Vibration free complete engine balance and weight matching
Omex 600 ECU with full throttle shift
Beam with 21mm Bars and a 30mm ARB, Xsara rear arms
Then onto the box, The most hybrid box ever I think, with BE1, BE3 and BE4 parts to make a nice C/R box with a 4.9 CWP complete with a very stiff Plate Diff
The onto the modded SD cage so I can fit Harness bars, Never liked fitting them to the shell behind the seat after this
Exhaust manifold now in production after test fitting on mine
And as it is now, almost complete
Then
Sanex Rods
JE Pistons
