Threads: 34
3
Car Model/Spec: phase 2 dturbo diablo
03-12-2012, 01:27 PM
Hey guys,
Not long joined the forum and I've been reading up masses about putting bigger turbos onto the xud, just wanted to see if anyone has attempted supercharging 1? Other than Darren whose videos I've seen both through the forums and YouTube. I
was hoping this would make an interesting project if its viable. Any ideas about if this would be any good?
Threads: 591
54
Threads: 34
3
Hmm, probably just a pipe dream then, will keep an eye out for a blower while I'm at the scrappy though.
Threads: 91
12
Car Model/Spec: 306 D Turbo
It is doable as Darren proved but chargers are expensive alone then you've got to mount the thing then you need to sort pulleys and belts etc. Don't get me wrong I would love to do it just for the noisebut I think you would be better off just going vnt instead
Threads: 591
54
We did it on a racing puma once...was epic...till it blew the head...but cost a fortune in 'one off' bits to make it fit.
Threads: 91
83
You could, but there's a massive amount of unused energy flying out the exhaust... Why not use that to drive a GOOD turbocharger...
Why do you think Mercedes have sacked off their Kompressor Eaton blowers and are now producing the CGI engines - because the bigger Kompressor engines were needing 150hp JUST to drive the charger, a Turbocharger is nearly free...
A new generation turbo will give you a far greater performance improvement...
Before anyone says Rotrex, there's a very good reason they're not that useful on Diesels...
Threads: 34
3
03-12-2012, 01:49 PM
(This post was last modified: 03-12-2012, 01:51 PM by RJDubya.)
But then you've got the awkwardness of the variable vanes, I know you can essentially set these up so they're actuator opened but its still gonna be tricky to get right, is it not?
Sure I've seen your car about londondan86, that picture taken in the Moss?
Good point ruan, takes a lot just to drive them, think that makes as good a sticking point as the cost.
Threads: 91
12
Yes mate that's the moss valley, you a Wrexham man are you?
As for the vnt, I've never set one up before but have done some reading, Ruan will be the best person to ask as he's been running one for a while now
Threads: 591
54
yeah but theres some serious work and setup and calculus to do to fit a supercharger!!! headache alert!
Threads: 34
3
Londondan, if that pictures where I think it is its about10 minutes from my flat.
Think I'll look further down the vnt route, are there any specific chargers people wouldn't use for that? The cars an everyday runner so I want it usable but with a bit of added poke.
Threads: 591
54
Threads: 34
3
That's a handy little tool, thanks... Will get on it
Threads: 91
83
http://www.youtube.com/watch?v=Lzc5EDff0e0
Why have a supercharger, when a properly tuned XUD9 will have next to no lag whatsoever...
Threads: 11
5
Given 2 thank(s) in 2 post(s)
have you done a thread on what you have done to you car sounds great in the video pulls very well by the looks/sounds of things
Threads: 115
The trouble is, if you aren't a computer genius (like Ruan) you will have a hard time setting up one of those VNTs judging from what Ruan has said. He recommends the GT2052 or 2056 which he said are perfect for these engines but you would still have to program the vanes to open when required and get a one off adapter plate made up.
Threads: 91
83
GT2052s or GT2056s?
Threads: 541
124
TBH an older (non electric) VNT could be controlled using a boost feed (with restrictor and plenum as necessary) and adjusting the actuator arm.
Threads: 91
83
But you then you might as well get a modern WG turbo... Those style ones are no better than the WG ones!
Threads: 129
11
Ruan didn't know you had a 6 speed?? Or do you? Gearing seems very short....
I'm deffinatly looking into VNT, doesn't seems as complicated to set up as I first thought.
Stage 2 XUD Sedan
Threads: 91
83
Did for a time, but for any normal driving its useless... I turned the gearbox oil silver in 2000 miles and destroyed the synchros on 3rd... They arent designed for high torque... And 3700rpm at 70mph isn't exactly ideal...
Threads: 129
11
That's not ideal Ruan. My old box was 3400 at 60 with the small wheels I had!
Ruan YHPM in 2 mins
Stage 2 XUD Sedan
Threads: 541
124
LOL 60mph at 2k for me.
Ruan youll probably have a similar PM from me at some point.
Threads: 55
3
(03-12-2012, 02:02 PM)Ruan Wrote: http://www.youtube.com/watch?v=Lzc5EDff0e0
Why have a supercharger, when a properly tuned XUD9 will have next to no lag whatsoever... Okay I want everything you've done to your Dtub, that sounds amazing and f*cking shifts
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Threads: 72
Car Model/Spec: 205 1.9 D Turbo (Full Gti Rep)
Given 1 thank(s) in 1 post(s)
is there a thread build link for ruans d turbo??
Threads: 226
24
Car Model/Spec: A3 TDi
Yeah use the search and you'll find it.
Threads: 91
83
http://306oc.co.uk/forum/thread-574.html
Not a full build thread, but explains most things
In fairness, there wasn't a build thread until I did that....
