Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Right my remote central locking is starting to bug me now, cant seem to find what's wrong with it just nothing happens from the key but there's a red light on the key so its not the battery
What i want to know is how hard would it be to swap from a ph2 CL system to a ph3 and what would i need for it ?
Don't want to go down the.route of aftermarket stuff
you would need a new ecu, bsi and key chip (all matching from the same car) and maybe a new loom. a lot of work for not much!
Threads: 164
25
Didn't think you'd need the ecu, that because its from a different phase or is it something to do with immobiliser ?
Threads: 36
18
Car Model/Spec: DT
Any reason you don't fancy going aftermarket ?
On the 306 waiting list.
(26-11-2012, 12:42 AM)rocker8742 Wrote: Didn't think you'd need the ecu, that because its from a different phase or is it something to do with immobiliser ?
ECU is coded to the immobiliser which is built into the bsi
Threads: 164
25
Just never been a fan of the aftermarket setups
Seems like a lot of haste to switch then, may have to try and get this setup working
Threads: 164
25
When i asked my insurer if i had an alarm fitted would it make it cheaper they told me it would go up lol
