Threads: 14
7
Given 5 thank(s) in 5 post(s)
My 306 failed on Sat, I was happy tho because it was 3 minor things.
I've fixed two but just wanted to double check my plan on the third:
It failed on the spare wheel carrier being insecure.
The adjuster is rusted solid and won't budge, it's soaking in WD but I don't hold out much hope.
My plan is to cut the adjuster and cage off and carry a can of flat mate in the boot.
Will this pass?
Threads: 198
135
Yup, can't test what isn't fitted. But if the adjuster is rusted solid and won't budge, how is that insecure?!
Threads: 14
7
because I popped the spare out to get access to replace the shocks - then it sat on my driveway for a couple of months while I twiddled my thumbs.
To be fair it was absolutely solid to undo, so I should have made sure it was properly free'd up back then when it still did move.
Threads: 198
135
Ahh right so there's no spare wheel actually there?
If you can live without it just cut it off.Pretty sure you can still buy the bar/catch thingy from Peugeot
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Given 2 thank(s) in 2 post(s)
Cable tie it to the hook. All my ajusters have been the same. Cabletie or shoelace I used in the past
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
