cyclones direct fit??
Hi guys, just been and brought some cyclones. I've always wanted a set of cyclones, and my mate told me there of a gti but will be direct fit on my 1.4 meridan, i went to try one on, the holes lined up perfect, but the steel ring around the centre part of the disk brake didn't fit into the alloys Sad does this mean i need wheel spacers?
Sorry for my lack of knowledge describing it.
cheers.
they are a direct fit, you may need to buy some flat styled bolts to secure them on though.
as long as your brakes are not bigger than 283mm they should be fine
[Image: sig.jpg]
Should go straight on as far as I'm aware!
I thought they would, I push them on, got one wheel nut in, and try get another nut in diagnal but it pivets on the steel :/ I measured the centre it of the cyclone it was 65mm and on the car couldn't get a good measurement but was around the same, it just doesn't seem to push back.
I tryed a bolt in the cyclone was exact same shape and enough thread on the nut.
they are straight fit . . . .but you will need the proper flat seated bolts, not sure what your problem is . . .Smile
Time to man up and show them some muscle I think!
Should be a direct fit to any 306!
You've had aftermarket wheels on there? Yes
Not left the spigot ring on the hub have you?
[Image: SDC10442-1.jpg]
I'm fairly sure, I don't think I had spigots rings tbh.
Got any pictures? Wheels inner bore, hub, and wheel bolts. Could help us abit
yeah sorry pal.
I would just clean up the hub lip and the center of the wheel, with some sandpaper, bit Of copper slip and push them badboys on
Yeah but a bit of sandpaper on it. Had steelies on before? Will be a build up on crap on the centre from where the steelies have no middle. I had it on mine
thinking about giving it ago, if i manage to get them on, does it matter that i dont have the flat wheels nuts? i have the tapered Wheel nuts.
yeah had steelies on it lol and okay mate il try it, hopefully! proper want them on.
Yes bud it does matter otherwise the tapered bit try's to work it's way through the alloy
You need the flat type else you'll risk pulling them through the alloy!
I had a set for sale but sold them with my cyclones!
Can pick them up easy enough tho!
okay cheers guys, il look out for a set
Donr take the risk with them nuts as it will reck the bolt holes on the clones and they will be usless for anything
(27-10-2012, 02:52 PM)CalNeedham3061.4 Wrote: okay cheers guys, il look out for a set
I've a set for sale
How much mate? And na I ain't taking the chance.
Alright again guys, just tryed fitting an cyclone again and still no success, I took my alloy off, and sanded the hub down, sanded the cyclone part down, and even got a file out on the hub cause there were a few ridges around it, and still won't go on? I can get 2 wheel nuts in and that's it, it pivvets of the hub, it seems there's only a few mm in it, any ideas ?? Sad
Helppppp pleaseeeeee!!!!
(30-10-2012, 07:40 PM)CalNeedham3061.4 Wrote: Alright again guys, just tryed fitting an cyclone again and still no success, I took my alloy off, and sanded the hub down, sanded the cyclone part down, and even got a file out on the hub cause there were a few ridges around it, and still won't go on? I can get 2 wheel nuts in and that's it, it pivvets of the hub, it seems there's only a few mm in it, any ideas ?? Sad
tried all alloys on both front and back or just one alloy on one hub?
this is a strange problem, in 4 years and 100000000 posts i've never heard of this before . .Smile
(31-10-2012, 06:05 PM)Mattcheese31 Wrote: this is a strange problem, in 4 years and 100000000 posts i've never heard of this before . .Smile
Not looking hard enough Tongue iv seen it once before .
I would just slowly wind in opposing bolts equally till it gets home! They gotta fit
(31-10-2012, 07:51 PM)Jonny b Wrote: I would just slowly wind in opposing bolts equally till it gets home! They gotta fit
Might be tight but should work
and what pray tell was the problem then? . .Big Grin
I have a set of 16 original Cyclone wheel nuts for sale including four lockers. Let me know if you're interested.
(31-10-2012, 10:21 PM)Pipps Wrote: I have a set of 16 original Cyclone wheel nuts for sale including four lockers. Let me know if you're interested.
I bet you don't, no 306 wheels came standard with will nuts... /pedantic
What are "will nuts"?
/pedantic
Another sarcasm attempt ruined, brought to you by auto correct lol Tongue
Users browsing this thread: 12 Guest(s)
