Threads: 117
119
As the title says really, any bright ideas for getting them undone? And none of this "man up" crap, i've just ruined a 1/2" t-bar trying to get them to let go
Alternatively, is there anyone nearby that feels like bringing round some uber-anti-hub-nut piece of kit for some beer tokens..?
Threads: 386
87
Front or rear?
I got the rear omes off with an extendable bar and 8stone of myself.......Fronts are on much tighter though.
Threads: 171
46
Given 1 thank(s) in 1 post(s)
Get a length of pole over the tbar for better leverage
Threads: 9
19
Given 3 thank(s) in 1 post(s)
impact wrench works for me.............
if you don't have one of those the i'm afraid that we are back to MTFU!
Threads: 202
58
Put a 1 foot extension bar out from the socket, with your t-bar on the end. Rest the extension on a axle stand, put a 2 metre length of scaffold tubing on the t-bar and hang on the end of it!
(helps to have someone to push the t-bar in towards the car so you don't round the nut off)
Threads: 189
10
Car Model/Spec: E39 ACS 535i
Given 2 thank(s) in 2 post(s)
I've got a 3/4 bar and socket with me, might be able to pop over with it to get them off if you want?
Threads: 24
Have you tried 'unstaking' it with a screwdriver. Sometimes that makes it easier once you've done that.
Threads: 9
19
Flynn Wrote:Have you tried 'unstaking' it with a screwdriver. Sometimes that makes it easier once you've done that.
Nah he will be trying to undo them with the locking pin still in :roll:
Threads: 117
119
^^^ wtf??
@ everyone who's suggesting more leverage, think you missed the bit where i f*cked up a 1/2" t-bar lol
And for your amusement:
Chris, if you've got the time and inclination that would be great, you've got a text...
Threads: 386
87
Err with that little thing not surprised it bent! You DO need more torque/leverage on the nut, it should come off smoothly with a long enough bar...
Threads: 9
19
If the "WTF" was aimed at me I was just humouring the troll.
IMO don't use a t-bar, use a proper breaker bar, I have a 1M one that is normally enough to get off anything, either that or snap the bolt
Threads: 386
87
mark_airey Wrote:Flynn Wrote:Have you tried 'unstaking' it with a screwdriver. Sometimes that makes it easier once you've done that.
I think he meant the rear drum nut stake lol, rather than the stake pin.  Poodle never said whether it was front or rear he was doing......
Threads: 92
43
Use a breaker bar, no extension, and a scoffold tube over the breaker bar
Threads: 9
19
Toms306 Wrote:I think he meant the rear drum nut stake lol, rather than the stake pin. Poodle never said whether it was front or rear he was doing......
No, really?! you think? :roll: your nearly as bad as him!
Threads: 117
119
Shut up Tom, it's not the size that matters...
And yeah it's the front i'm doing, sorry.
Was aimed at mctrollerson, not you Mark. Breaker bar wasn't up to it, was flexing horribly and the nut didn't even think about moving. It's only an old 600m jobby, so not exactly up to it.
Threads: 386
87
mark_airey Wrote:Toms306 Wrote:I think he meant the rear drum nut stake lol, rather than the stake pin. Poodle never said whether it was front or rear he was doing......
Lol  How did I miss the sarcasm in your post!? Nevermind, as you were lol.
Threads: 386
87
Poodle Wrote:Shut up Tom, it's not the size that matters...
Size does matter.....well thats what they all tell me anyway.  hock:
Ah I haven't done fronts, but still, a long enough bar should be good enough.
Threads: 87
31
When we did Jakes he got his uncle to weld a 6ft "2 steel pipe onto the socket. Came off a treat :p
Threads: 87
48
Connor Wrote:Use a breaker bar, no extension, and a scoffold tube over the breaker bar This^^^^^^^^ and you still might have to man up! sometimes they are just stupid tight .
Threads: 177
3
Get a bigger socket set, 3/4 or 1", 1/2 is just to small
Threads: 117
119
Big thanks to Chris (DTS) for sorting the wheel bolts for me, came over with the 3/4", came off easy with the bar.
Threads: 189
10
