24-10-2012, 03:41 PM
how easy is it to change the locks and ignition barrel on a phase one dt?
also is it expensive to do?
lock change
24-10-2012, 04:02 PM
Door locks are easy. whip the door card off and holding the lock in is a metal c shape plate. Pull this out with a pair of pliers and the lock will just pop out.
Ignition barrel is a bit fiddly. You have to take a small screw out then push in a tab on the bottom of the barrel as you turn the key from off to first position.
24-10-2012, 06:21 PM
cheers dude where can i get new ones from.
| boot lock change. | Joe | 10 | 5,623 |
26-03-2012, 11:54 AM Last Post: declantg |
