Threads: 151
14
Car Model/Spec: 306 D-turbo
Couldn't find a transmission section or I'm going blind.
Anyone had any experience with these on a D-Turbo ?
Thinking of buying one but for £22 I can't see them being up to much?
Cheers
Team Doesn't own a 306
Threads: 132
sure there was a group buy on the other pug site.
I would like to know myself
Threads: 151
14
Yea I heard there was a group buy, want a quickshift so just wondered if anyone had tried one of these?
Threads: 61
Given 6 thank(s) in 5 post(s)
i uaave one on my s16 its pretty good havent had no issues at all.
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Iv got one they are ok. But i find it dosnt bring the throw in far enough for my liking
but i have got it on a 6 and it has brought it into the same post code now but still needs to be shorter
Threads: 151
14
Mixed reviews then think I may get one and butcher a old stick I have to make it even shorter
Threads: 124
26
Car Model/Spec: Megane DCiR
I have one of these and with the original allen key and nut they slip but if you get a better bolt it works a treat, i roughed the gearbox spigot up a bit with a rough file and fitted, works a treat and also cut gearstick down a tad for bit better throw
Threads: 86
deffo cut gearstick down a bit and install one well worth the money!!
Threads: 208
60
Dont get me wrony danny. For the money they are good. Just not all that grate on a gti. I image it would be alot better on a DT. Especialy if you are goin to cut the gear stick.
But as CJ say. Drill the bolt hole out and put in a larger one with washers before you fit it. Also i gave the Q/S its self a good rough up with a file to stop the slipping as it was doing my head in
Threads: 151
14
May invest in one then, I was thinking about welding a extra inch or 2 under the white ball / pivot point would that make any difference?
Threads: 208
60
Intresting thought . Cant see how you go about it. I cant see how youd extend it unless you got BBM linkages that you could turn one end upside down.
But your on the right track. The lower you can get it the shrter the throw will be
Threads: 151
14
I mean the actual gear stick lip a inch of the top and weld it in under the ball?
Threads: 208
60
17-10-2012, 01:30 PM
(This post was last modified: 17-10-2012, 01:30 PM by puglove.)
Its bigger than that any way. And slides to the bottom of the saft.
Giggity
Threads: 236
36
Worth it on a HDi?
I don't want to shorten my shaft (ooer) because it's not a reversable mod. Oh, and getting the gearknob off in the first place is a c*nt of a job! Nearly steralised myself when I last did it on my XS!
Threads: 208
60
Prob would be worth it.
It is a reversable mod. Its a fairly easy job to jam another un cut gear stick in there if you ever wanted to go back.
