BYEBYE
2.1 conversion done........
09-10-2012, 04:02 PM
got any pics of the conversion?
Stealth 3door Dturbo - In progress
http://sphotos-d.ak.fbcdn.net/hphotos-ak...6076_n.jpg
09-10-2012, 04:54 PM
You got any pictures of the dyno graph?
Sounds very good if you got 443lb.ft torque...
09-10-2012, 04:56 PM
09-10-2012, 05:03 PM
Also - running without cambelt covers - you're braver than I am!!! I ran without a top pump one for 5,000 miles and the belt had taken a significant beating from stones and little bits....
When does that 18g come on boost around?
09-10-2012, 05:14 PM
I would be interested to see the graph for this, nice work good results. Any build pics?
09-10-2012, 05:18 PM
Nice to see you got this up! It's a beast of a 306 looked awesome down MFN. Was nice to meet you dude!
09-10-2012, 05:37 PM
09-10-2012, 06:26 PM
Very good results there matey!! Woukd be nice to see dyno graph too? Im running a 15g most run 13t and i can imagine the 18 wil pull very well crazy torque figuires for one of these, im impressed what size bosch you running? Mods etc?
CJ
09-10-2012, 06:54 PM
(09-10-2012, 06:26 PM)CJ_Derv Wrote: Very good results there matey!! Woukd be nice to see dyno graph too? Im running a 15g most run 13t and i can imagine the 18 wil pull very well crazy torque figuires for one of these, im impressed what size bosch you running? Mods etc? 12mm pump 201bar injectors in line fuel pump....forged internals turbo is a hybrid...Gets full boost by 2000 rpm comes in at 1800....really good...
09-10-2012, 07:10 PM
Looks like a pretty clean / well thought out build....
Wasnt this dyno'ed without a tacho tho? Or some kinda issue on the dyno....Or am I thinking of the wrong person...pretty sure im not though... Torque seems VERY high given the output.... Is the gate welded in those photos? Id say you could probs get fair bit more from it if so as the fuel must be pretty lean to be keeping the boost as low as that... | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
09-10-2012, 07:12 PM
That's what I was thinking, because unless it made it's FULL torque at 2200rpm and then completely died, it wouldn't make that torque figure? Sure that wasn't NM torque, that'd make a LOT more sense... A WG turbo just can't produce those sorts of torque levels - especially on an XUD head, the poor turbo would surge out of control else!!!
09-10-2012, 07:16 PM
Ruan im pretty sure like I said there was an issue with the dyno, hence results really not meaning much...
09-10-2012, 07:55 PM
Hmmmmmmm sorry i dont buy the TD04 '18g' hybrid, the 18g wouldnt fit the TD04 just clicked in my head then, they only turbo the 18g fits is a TD05 !and it would be a hell of a lot bigger than yours pictured, ive looked into these soo much as im currently working out the best combination for a hybrid with local turbo shop . Its certainly something to have full boost by 2k but if what is said is true about tacho not working how do you know this?
Not pissin on your chips but just doesnt add up this tbh, im no expert but thats some serious torque for one of these
09-10-2012, 08:14 PM
Turbo looks like a 13t in the photos.....Where did you get the 18g compressor etc?
| #DervMafia | (09-10-2012, 08:14 PM)darrenjlobb Wrote: Turbo looks like a 13t in the photos.....Where did you get the 18g compressor etc? Just edited my post the 18g wudnt fit the TD04 and that looks exactly like mine but mines a 15g I apologise i stand corrected there is such thing as a td04-18g but looks nothing like that check linky it would be huge and actuator bolts in front too http://www.toyotagtturbo.com/forums/show...td04/page3
09-10-2012, 08:33 PM
Cant see the dyno results mean anything at all really, running with no tacho is really rather pointless as no way to convert the wheel torque into any form of fly hp / torque so all a load of guesswork....as Ruan said, to make 200hp at 400+ ft pounds would simply be impossible, I doubt even a gen3 VNT could do that on an xud let alone a big wg turbo, espically not with an apparent 18g compressor..
09-10-2012, 08:35 PM
Anyone remember what torque jamma made runnin 209bhp?? And what could you get a 12mm head off ??
(09-10-2012, 08:10 PM)CJ_Derv Wrote: Hmmmmmmm sorry i dont buy the TD04 '18g' hybrid, the 18g wouldnt fit the TD04 just clicked in my head then, they only turbo the 18g fits is a TD05 !and it would be a hell of a lot bigger than yours pictured, ive looked into these soo much as im currently working out the best combination for a hybrid with local turbo shop . Its certainly something to have full boost by 2k but if what is said is true about tacho not working how do you know this? I think you need to do research as I had mine built and it is a hybrid....... (09-10-2012, 08:33 PM)darrenjlobb Wrote: Cant see the dyno results mean anything at all really, running with no tacho is really rather pointless as no way to convert the wheel torque into any form of fly hp / torque so all a load of guesswork....as Ruan said, to make 200hp at 400+ ft pounds would simply be impossible, I doubt even a gen3 VNT could do that on an xud let alone a big wg turbo, espically not with an apparent 18g compressor.. I am running with tacho And has been dynoed with tacho since the first time....
09-10-2012, 08:43 PM
Put tape measure across that compressor housing inlet with photo taken looking straight in, Just intrested to see whats going on as in the other pictures it honestly appears to be a 13t compressor....We are just interested....
09-10-2012, 08:53 PM
(09-10-2012, 08:43 PM)darrenjlobb Wrote: Put tape measure across that compressor housing inlet with photo taken looking straight in, Just intrested to see whats going on as in the other pictures it honestly appears to be a 13t compressor....We are just interested.... It is NOT a 13......it came as a 15 off a bug eye had it rebuilt...at CR Turbos.....Anything else Darren????????????
09-10-2012, 09:14 PM
09-10-2012, 09:16 PM
Strange....... just looked at newbie thread and im sure you wer in the middle of building a 2.5? We are only curious as manyof us have explored different avenues and possibilities for these cars and not long ago you were asking if a 1.9 gearbox fits a 2.1 now your telling us youve got a 12mm pump IMO unheard of on a 306 application and a turbo thats twice the size of you pic
Of course we are going to question it as many on here are extremely experienced and have awesome knowledge It just simply doesnt add up... soo can we see this dyno then??
09-10-2012, 09:22 PM
Cool build. But would like to see the graph as well as mine only produced 220ft-lb at 175bhp on the last dyno before the clutch let go.
Stage 2 XUD Sedan
09-10-2012, 09:24 PM
I know of a 306 that was running 12mm head.....
09-10-2012, 09:28 PM
Yeah just found out 12mm heads are popular i didnt know this but turbo is certainly incorrect as iv been looking into this a lot as i was telling 4waydiablo on fb other night
I was thinking this strictly_derv as your figuires popped into my head and youve got a very nice setip there should be fun when a fair few of us have a dyno on saturday |
