advice please
hello guys i need your advice. i went out on a test drive in a 306 hdi. the car ran out of fuel so we put more in it and it was taking ages to start. we got it started but the management light stays on now and its sounds a tad tappy. what do you think it is and do you think i should stay well away?
thanks in advance guys Tim
Doesn't sound out of the ordinary, last time i ran out of fuel i had to crack all the investor lines off to get the air lock out. The fault code will be "low pressure to fuel pump" or something like that, mine went off by itself after a day or 2. And the thing id be most worried about, is that they let you test drive it with not enough diesel in the tank, i mean if i was selling any car id make sure there was enough fuel in it...
the guy has just bought an a4 and dosnt use it but its had fortunes spent on it
I ran out of diesel once. I disconnected the battery for a bit and it went. It's a soft code that clears after a few successful cycles Iirc.
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
nice one guys thanks for the info
Crack off the injector lines? On an HDi? When there's a perfectly good auto-priming system? Connor i worry about you....
Running out of fuel doesn't do these engines any good, if it's now magically sounding tappy i'd be wary. Without insulting your intelligence, is it much more tappy, or is it a marginal thing that could be partially imaginary, if you know what i mean? Could just be where you're listening for problems now..? There anything else wrong with it?
