Car revVing up
Car revVing up
Pulled of this morning in first gear fine, then went into 2nd and it just revved to the redline all the way through to 5th any idea what's up
You have no control over your right foot?
Haha no its like the clutch is gone or summat
Sticky injector, oil leaking into the cylinder, sticky throttle plate?
Would you say it's the clutch it's like it's stuck cuz it revs up loads
Sorry, misread your post
does it do it if you drive gently or only when you put your foot down
When you put your foot down
Clutch then, Is there an oil leak coming from under where the engine meets the box cos it could be a crank seal leaking causing the slippage if not itll just be the clutch.
If you want a good price on a replacement then www.krisb.co.uk is a good bet.
Wicked will have a look tomoz cheers
yeah kris did my clutch and did it very quickly for a good price with genuine parts. worth the drive if you can make it!
  Over revving? underground375 18 7,248 18-11-2013, 11:32 PM
Last Post: Niall
