swivel pins HELP
swivel pins HELP
Are swivel pins the same across the 306 range or is there variations
I think its called a swivel pin anyway the bit the strut ball joints and hub bolts to
Swivel pin? I thought the ball joint bolts to the hub?
If it is ballpoints you mean then there are two sizes 16mm and 18mm
What it is i bought my car a few days ago and the bit where the bottom ball joint slots in the slot is conical. So the nearside front turns in when you put your boot in its a dealer only part so was gunnna get 1 from scrapyard
  GTi caliper pins, new, needed...where to?! Piggy 8 4,335 17-06-2016, 07:50 AM
Last Post: Anton
  Front caliper refurb - stuck slider pins 306rhys 11 5,152 12-07-2015, 02:36 AM
Last Post: HDi--Power
  gti brake pins martyn92 4 3,202 23-12-2012, 06:10 PM
Last Post: martyn92
