Threads: 80
5
Car Model/Spec: 2006 Honda Civic 1.8 VTEC Ex
Given 5 thank(s) in 5 post(s)
Red circle nut! Ive soaked it in WD40, no luck, putting lots of force on it, only warps the plastic on the other side (which i've now done to both)
Ive tried putting needle nose pliers on the the funny flat (blue) part, but no luck!
Can anyone help/give any suggestions?
Threads: 82
27
Have you tried a lot of shouting and swearing at it? I hear that works well
Threads: 80
5
(15-08-2012, 09:36 AM)Midnightclub Wrote: Have you tried a lot of shouting and swearing at it? I hear that works well
Yes, mainly after I stabbed my self with some needle nosed pliers
Threads: 27
20
Pair of mole grips on the end of the shaft and undo with a spanner, just enough to then get the grips on the flat bit
Threads: 80
5
dont have mole grips ![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png) I need more tools
Cutting the nut off with a hacksaw now
Threads: 150
14
Car Model/Spec: 306 HDI
get up, unzip trousers, pull down boxers, lean back and then lunge forward and Dick smash it was the force of 1000 suns
306 HDI, soon to be XUD
Threads: 6
6
Car Model/Spec: PH2 sexual tyrannosaurus
15-08-2012, 10:11 AM
(This post was last modified: 15-08-2012, 10:14 AM by Skank_army.)
Try heating up the nut with a blowtorch, obviously being careful not to melt the plastic, then douse it in WD40, then more heat, and repeat till it frees off. If you try cutting the nut off, you will most likely ruin the thread on the stud.
(15-08-2012, 10:11 AM)declantg Wrote: get up, unzip trousers, pull down boxers, lean back and then lunge forward and Dick smash it was the force of 1000 suns
FLOL!
Repped.
Member of Team Rather be Gay than Ginger
Threads: 80
5
(15-08-2012, 10:11 AM)Skank_army Wrote: Try heating up the nut with a blowtorch, obviously being careful not to melt the plastic, then douse it in WD40, then more heat, and repeat till it frees off. If you try cutting the nut off, you will most likely ruin the thread on the stud.
Its not a visible part at all (the nut and thread im trying to get off will be hidden behind the bumper.
New plan is a cheapo angle grinder. Been hacksawing for about 20 minutes and not even done half of it!!
Threads: 6
6
(15-08-2012, 10:17 AM)cpikey316_ Wrote: (15-08-2012, 10:11 AM)Skank_army Wrote: Try heating up the nut with a blowtorch, obviously being careful not to melt the plastic, then douse it in WD40, then more heat, and repeat till it frees off. If you try cutting the nut off, you will most likely ruin the thread on the stud.
Shit mate...... ummmm, bumper off?
Threads: 386
87
(15-08-2012, 10:17 AM)cpikey316_ Wrote: New plan is a cheapo angle grinder. Been hacksawing for about 20 minutes and not even done half of it!!
Erm.....try a new blade on the hacksaw lol.
Threads: 448
51
Mtfu. Keep sawing.
Or get a new blade yours is obviously blunt
Threads: 80
5
(15-08-2012, 10:18 AM)Skank_army Wrote: Shit mate...... ummmm, bumper off? ![Confused Confused](https://www.306oc.co.uk/forum/images/smilies/confused.png)
The foglights arent on the car yet, thankfully. The numpty who sold them to me no doubt just ripped them off
(15-08-2012, 10:32 AM)Matt Wrote: Mtfu. Keep sawing.
I can find more uses for an angle grinder!
Threads: 163
53
Car Model/Spec: 406 HDI
Threads: 0
45
Threads: 208
60
got a vice? if so use that to clamp the end of th thread
Threads: 541
124
Snap the plastic then glue it back together once youve removed the nut.
Threads: 80
5
(15-08-2012, 08:06 PM)Dum-Dum Wrote: Snap the plastic then glue it back together once youve removed the nut.
I ended up doing this accidentally afte grinding the nut away!
glued plastic is currently drying in my garage
