K03 MBC
K03 MBC
Has anyone got any pics of a MBC fitted to a K03? I understand how they fit on a GT15 but can't quite work out where it would go on the K03.
Any help appreciated
no expenses spared...
[Image: A5mpp.png]
haha cheers for that ginge.. it's not quite the same on a K03 though, think the boost take off to the actuator is done through a banjo bolt
you got any pictures to where you have access to ??
Nothing useful i'm afraid.. but i know there's naff all room. Hopefully someone who's already done it can pop along with a decent pic Big Grin
Cut the metal pipe in two, then jubilee clip some hose around the 2 bits of metal pipe.
ginge191 Wrote:no expenses spared...
[Image: A5mpp.png]
that MBC is actually the wrong way round..
just sayin'
What he said ^^ Flip it so boost is pushing spring not how it is Smile
[Image: sigi-2.png]
Cheers guys, What should i use to cut the pipe? Thinking about it won't it squash the pipe then give me effectively de-wastegate?
Just cut it with penknife or something, its only a tiny rubber hose....
Better still remove it at both ends and run two longer new hoses up to somewhere easier to adjust!
[Image: sigi-2.png]
Ah ok, ruan said it was a metal pipe? I've already got some hosing which i should be able to use, I'll take a load of pics when i do it for anyone else wondering
If it's got a banjo bolt I assume it's a metal pipe?
I know the K14 uses a metal pipe, K03 might not - either way, just shove it someway between the two?
Okay mate, it was difficult to see so not sure if it's a metal or rubber pipe, I'll see if i can get some decent pictures then that should tell me
rubber pipe will be black and bendy, metal pipe will be metallic looking and not bendy Tongue
Team Orange Engine Bay
mark_airey Wrote:rubber pipe will be black and bendy, metal pipe will be metallic looking and not bendy Tongue
Unless it's all oily because i had a boost leak... in which case.. everythings black Tongue
Midnightclub Wrote:Unless it's all oily because i had a boost leak... in which case.. everythings black Tongue
The bendy rule still applies though Big Grin
I could do with pictures of this too.
I'll be setting one of these up on a K14 soon. How easy is the pipe to access from underneath? Also what is the diameter, if anyone knows. Thanks.
Jonny81191 Wrote:I could do with pictures of this too.
No you couldn't, man up Tongue
for the GT15, i just cut the pipe half way roughly, then pushed 2 fual line connector barbs in, then a few feet of blue silicone pipe up to near the top mount.
oh and i think its 5mm internal diameter, as the 6mm barbs i used were tight as f*ck..
get round to mine of an evening and help then!
