Mileage
Mileage
Hey guys still looking for a 306 found one but its got 175000 on the clock ive seen some with alot more any advice?
Some more info might be useful? Petrol? Diesel? Hatch? Estate? etc.....
All depends on the model & service history, if it's a dt/hdi with history saying that it's been regularly serviced them there should be no problem.
If its a xsi/gti with no service history, I'd say no!
On the 306 waiting list.
My old ph1 hit 202k I do believe..
Go for it.
my HDI has 141k
202k it had before i stripped it, engine was running perfect still.
Team Doesn't own a 306
Sorry its a 1.9 Td lx.
Dosent say anything about Serive history.
Go for it! Tds go on for years
(10-08-2012, 12:11 PM)Matt Wrote: Go for it! Tds go on for years
Yeaaaaaaaaahhhhhh .............. Huh
Id check it out a bit more 1st mate. Ring up as about the history , if its got FSH or even PSH its worth. Going to have a look at. When you get there jist check the engine over a bit better when you get there. I.E all levels , check the top of the oil/ warter cap for signs of if the head gasket has gone or if its bin done in the past. GoThen take it for a good long test drive . Keep an eye on temps and listen out for unusal noises.
If all seems good it should be good for as long as look after it
Yea il go have a look need a car next week so running out of time Confused
I bought mine 146k hdi. Full service history. I've done well over 10k in it so far and still runs perfect. Engine wise all I've done it usually cam belt aux belt and service. I had problem with crankshaft pully other week and that was it Smile.
170k and still going strong!
my HDI that is :p
[Image: ForumSignature.jpg]
