Threads: 343
15
Car Model/Spec: 106 gti / 306 hdi estate
Given 3 thank(s) in 3 post(s)
As above really how can i remove the off set washer i had the same problem on my 106 the off set washer was stuck in and now its the same with my 306 i tried all sorts with my old 106 heat, wd40, hammer, a bigger hammer, shouting and swareing but it still didnt move...... just had a go with the 306 and its the same rusted in how can i get it out?????
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Wire brush drill bit to clean it out
DW40 lots of it
dig the crap out wiv a small flat head so it has some where to go.
A blower on the air line to blow the crap out. (as much pressure as you can get in the compresor helps)
Some hard blows with a center punch/chisel.
Should do the trick
Threads: 22
6
Car Model/Spec: 306 HDi Stage 1
As above, works every time
Threads: 90
54
Did you watch my video? Think i showed using a chisel / screwdriver to knock them down...
