Threads: 208
60
Given 5 thank(s) in 5 post(s)
Right after seeing a expert van with the front wheel off next door earlier i noticed it had twin pot caliper. Now this got me thinking as pretty sure they have the 15" steels on. Now im thinking this may be a good cheap solution aswell as a fairly good way to retain my cyclones with the low bost.
So to start any one ever had any experience with these calipers
would these give much benifit over standered gti brakes? As these van do have over a 2 tone gross weight
Would i actualy even be able to fit these? With ouy spending silly amounts of cash
Will any one actually make any decent pads for these calipers?
Finaly can any one actually answer these questions lol
Threads: 208
60
I havent researched disc size, but if i can make up a bracket/spacer i maybe able to use a gti disc therefore solving the 5 stud issue, either way though you should be able to find a 108x4 pcd disc to suite the calipers
Threads: 198
135
How are the calipers fitted to the expert? Will they need adapters for the 306 hubs?
Also what's the total surface area of the pistons compared to a gti single piston? Almost pointless upgrade if surface area is lower and disc size is smaller. More even brake force yes, but more pistons =/= better braking all the time
Threads: 208
60
Well to be honest iv done no research on the subject as of yet, they look to be 283 or bigger and the pad surface area looks to be alot bigger but like i said done no research yet, i may do inabit if i get a chance
Threads: 198
135
Have a look If you get chance. See loads of experts in the scrappies, brakes would be cheap as hell to buy and nowhere near as rare as the 302mm ones.
Will do some digging myself actually!
Threads: 208
60
1st bit of research 285 disc so so has to be better than a 6 caliper right?? also rann on the 807
Threads: 198
135
Only better if they provide more braking force than a gti caliper, surface area means more contact between pad and disc but they need to deliver a good braking force too.
Generally speaking if the total piston size is more than the gti then yes, they'll provide more braking force. Also can you tell if they're lug or radially mounted? If they need adapters machined they wouldn't be worth the effort.
There's a nice set of 607 brembo's on eBay for a bargain at the mo, wonder if they'd fit..?
Threads: 92
43
Just to add my bit to this thread, there are a few different sized brakes on the expert from about 01-07, a 15" disc and 2 different 16" discs
Threads: 541
124
The 4007 has twin piston calipers too. I have a set here that id be willing to sell cheap. Theyer not a straight fit as the 306 uses 80mm bolt spacing and the 4007 uses 130mm (ish)
Threads: 198
135
Ahh the expert ones won't fit easily then either, they're roughly 100mm+
What about 307 HDi brakes?
283mm, but thicker discs and the calipers are bigger... Heavier yes, but not massively...
