Speedo dropping?
Speedo dropping?
I'm experiencing a problem where my speedo will drop.. Completely random, and I've read that it needs the sensor cleaning which is fine.. What worries me is that it drops in power when it does it yet I thought that only happened to mapped ecu's I'm confused as I'm sure mine is standard, but was going to get a stage 1 done soon...
[Image: signature.png]
So is it the needle dropping or the drop in power causing it to drop speed?
Stage 2 XUD Sedan
(19-07-2012, 03:42 PM)strictly_derv Wrote: So is it the needle dropping or the drop in power causing it to drop speed?
The speedo will drop then I lose power... It's just like my turbo goes 'NO IM NOT WORKING'.. Then it's fine when the speedo picks up.. It can happen in any weather conditions or speed..
my speedo drops every no and then but does'nt effect the power.
I dont mean in the sense that I lose all power it just seems to lose its grunt Sad
My speedo has dropped occasionaly too
The power loss is normal on hdi. The hdi ECU is one of the only 306 ECU that uses the speed as part of its calculations iirc. Sort of puts the car into a limp home mode. Bung a new sensor on there (cleaning won't do anything) and leave the battery off for half hour or if you know someone with pug planet, get them to clear the fault.
(19-07-2012, 04:52 PM)Niall Wrote: The power loss is normal on hdi. The hdi ECU is one of the only 306 ECU that uses the speed as part of its calculations iirc. Sort of puts the car into a limp home mode. Bung a new sensor on there (cleaning won't do anything) and leave the battery off for half hour or if you know someone with pug planet, get them to clear the fault.
Thanks Big Grin
Anyone know where the sensor goes and what part number the sensor is? Mine keeps dropping but has no affect on power.
It's on the back of the box on the diff. If your looking at the engine from the front, find where the drivers drive shaft enters the box and it's there.
  rev counter dropping out doski 7 2,046 20-06-2014, 06:16 PM
Last Post: toseland
