The car leaking still...... well when I got it the aerial was leaking so I fixed that cause there was water on all the floor I could have fish in there!
The next problem the back doors but Ive ajusted those so now those dont leak!
Now the passanger front door leaks somebody cut the metal lip from underneath were the rubber goes near the dash in one small part. Why the hell would you do that unless boding speaker wires or something perfectic. They put silicon were the cout was made in the rubber it never worked sad or wat!
So Ive had to get rid of that rubber it would leak Ive got anther from the scrap yard but it leaks. Ive ajusted it tried everything Im just not sure what the hell the problem its got to be the scrap yard rubber no good?
The driver door if the water the same it trys to leak in the same place there but its harder to leak there. Is there a common thing with this leaking or wat!
Old rubber cut then silicon sad! but were the cut is piece metal gone on that bit nuts!
![[Image: DSC01364.jpg]](http://i210.photobucket.com/albums/bb241/Welshy_Pete/Peugeot%20306%20hdi%20repairs/DSC01364.jpg)
Fitted anther rubber but this problem now!
![[Image: DSC01682.jpg]](http://i210.photobucket.com/albums/bb241/Welshy_Pete/Peugeot%20306%20hdi%20repairs/DSC01682.jpg)
![[Image: DSC01681.jpg]](http://i210.photobucket.com/albums/bb241/Welshy_Pete/Peugeot%20306%20hdi%20repairs/DSC01681.jpg)
Ive tried passanger front side moving the rubber around the frame in diffrent ways but still leaks in the same place!
The driver side just about holds but does leak abit in the same place!
Both doors are ajusted right in the most they can as well.
