08-07-2012, 06:25 PM
Ok so i have bosch pump unknown condition, before i put it on and do the cambelt are there any checks i can do to see if its all good?
How to tell if a Bosch pump Good
08-07-2012, 06:28 PM
I'd check to see if it's been modified before. Max fuel, lda etc
08-07-2012, 06:33 PM
First time every holding a bosch, what are the obvious signs its been messed with? I assume i have to turn the max fuel and see how far it moves?
08-07-2012, 06:42 PM
I really have no idea. I don't do diesel. If go look in the guide section about modifying a bosch pump. Look and see what they do/turn/hit and see if that's been tampered with on yours
08-07-2012, 06:56 PM
if its untouched it will still have anti tamper markings in yellow and the fuel screw will have a metal crimp on the thread
Perv 306 1.6 5 Door Hore - Sold 110bhp 207 Hdi Sport - Used as a Brake 173bhp T25 Ph1 Diablo Dturbo - Scrapped Thirsty Bitch Volvo 850 Estate - Sold 51bhp Berlingo Nad DT Van - Sold Slow as f*ck Dispatch Work Horse www.prestige-auto-care.co.uk
08-07-2012, 06:58 PM
Worst thing to worry about is if the pumps been stood dry it'll rust the insides
08-07-2012, 07:16 PM
As Dave said, really if its been stood, id want to open it up before I bothered fitting it...nothing worse than a stuck vane pump after fitting it....
08-07-2012, 07:53 PM
Basically as Darren said, you'l want to open it up and check its insides arent rusty, to do this just check out one of the many 'gov mod' guides, and that will talk you through how to open it up
08-07-2012, 08:13 PM
Thanks guys, think i will be opening it up and checking it out, im going to hope if it is rusty i can give it a derust
08-07-2012, 08:16 PM
Tbh even if its not rusty, ive had ones with bad pumps...infact rust is often only a minor issue / they work fine anyway, it really comes down to if the vanes are stuck / gov weights are tight, either of which will screw it up totally.
08-07-2012, 08:22 PM
Ok so i didn't know what the vanes were, this is a bit unknown territory for me.
So a quick search and i find this: http://www.dieselbombers.com/1st-generat...ation.html May be helpful if anyone in future reads this. Im going to assume that if things are stuck its not worth trying to rectify it.
08-07-2012, 08:25 PM
For sure, its very hard to ruin a pump totally from standing, the rust has to get pretty bad first...its much easier to ruin it by running it dry!
08-07-2012, 08:29 PM
Lets hope for the best, i will have a go at taking it apart and see how bad rust is if there is any, i know when i moved the pump a little diesel did leak out but not much.
08-07-2012, 08:37 PM
If you moved it and some came out, chances are its totally fine you're just worrying. When its dry it is literally dry.
08-07-2012, 08:54 PM
Im worrying because didin't wanna fit it all and find its duff
I still need injectors, i know of someone breaking a fiat Scudo 1.9td but im unsure if its got the same as 306 pump or the 406pump as if its usefull to me then i may get it off him
09-07-2012, 11:56 AM
When i got my pump though it was full of diesel but when darren fitted it the vane pump was seized up and had to be taken off and freed up then put back on again....
09-07-2012, 06:46 PM
I'd fully remove max fuel screw, if the end is rusty then avoid, or take a risk.
16-07-2012, 05:04 PM
Still haven't split the pump as ive been avoiding it but... If i am to turn the cam wheel by hand should it turn freely or get hard to turn then free then hard to turn again?
16-07-2012, 05:47 PM
Should be smooth for a quarter tur then hard then smooth etc
16-07-2012, 06:03 PM
Ooooo, that makes me feel better i thought it was fooked as the lucas turns freely and the bosch didn't, i know the insides are different on both. It was still hard to turn as you say every quarter then easy.
I put some fuel in the bosch turned it and it with socket and fuel spurtred out in order from the outlets I may take a risk and just fit it.
16-07-2012, 06:22 PM
Get on and get it fitted, the worst that can happen is you put a Lucas on
16-07-2012, 06:27 PM
well i was worried that as it became hard to turn at some points then cambelt wouldn't be able to turn it and end up snapping and then ide have a fooked engine. You can see i do overly worry about things.
16-07-2012, 08:01 PM
just do it man! worst that could happen is you end up getting a hdi so you dont have to worry about these things
16-07-2012, 08:04 PM
16-07-2012, 08:09 PM
As above i have my own hdi thankyou. This isn't for my car im building it for my other half.
16-07-2012, 08:16 PM
Can see why you don't want it to blow up then, otherwise she'll be giving you that look and "you just couldn't leave it alone could you.." . Learnt alot from my parents
16-07-2012, 08:20 PM
Haha exactly. I already want to FMIC just because the engine is out and easy to swap over the manifolds ready for when i inevitably up boost.
Slack in bosch pump? | dt_ | 14 | 3,460 |
21-10-2020, 03:41 AM Last Post: dt_ |
Bosch pump help for newbie | PugRy | 2 | 1,996 |
05-01-2020, 09:09 PM Last Post: jamie182 |
Bosch pump fuel screw broken | Forby | 0 | 1,492 |
12-03-2019, 06:47 PM Last Post: Forby |
