16-05-2016, 05:09 AM
at least it works piggy who gives a monkeys, you want to see the welding I did with my gta, and it still lasted to the day I binned the shell!
Mrs Piggys 206hdi - written off.
16-05-2016, 06:38 AM
(15-05-2016, 09:44 PM)Piggy Wrote: No...ripped old one off...put "new" in position. Welded it in position with a slingshot from a distance. EFA Looking good otherwise! Welding and fabrication projects undertaken, contact me for more information.
07-06-2016, 09:05 AM
Ignition switch is an easy fix but a £1 switch was quicker and cheaper right?
07-06-2016, 09:09 AM
blast off button
07-06-2016, 06:08 PM
MOT passed today...
Only due on 26th March Only advisories were tank strap corrosion and rear offside axle bush, the rubber bit. But still got the gti one to go on. All good for 12mths Wishes for more power...
27-06-2016, 07:58 PM
So mrs piggy and I havn't cleaned the car in/out for months and I have never polished or waxed it...
So gave it some love... Used some Autoglym tar remover...despite its reviews it sucks...so the petrol came out. Used some simonz black trim restorer and some megs polish and carnuba wax. The car is in shock. Mrs Piggy gave the inside a spring clean too. In other news...need an ignition barrel Wishes for more power...
27-06-2016, 08:03 PM
A lot of the Autoglym stuff isn't as good as all the hype tbh. I use other brands for most stuff now.
The 206 looks good though!
27-06-2016, 08:27 PM
Autoglym Intensive Tar remover is one of if not the best thing that they make.
There is a knack to it, you need to soak it putting on a heavy coat with a rag and leave it for a minute then rub out the spots frequently changing to a clean part of the cloth and applying a fair dose of the stuff. It's certainly better than petrol in my experience.
27-06-2016, 08:46 PM
Haha...petrol was wipe on, wipe off.
The autoglym stuff was seriously hard work. Wishes for more power...
10-08-2016, 09:33 PM
This is just chugging along... 130k ticked over now.
Had a bump in town...was parked up, someone else bumped it. Going through insurance now. Will use mickey and give it few bob more to sort the crease out on the n/s. Tidy the old gal up a bit. The 6yr old osram nightbreakers gave up...so £13 later and a new set of nightbreakers "unlimited" whent in this evening and a replacement o/s/r light unit as old was kept getting damp and was dim. Thanks brad for that. Replaced broken tow plug too. Trying to tidy it up a bit. Helix clutch next. Then fmic time... Should really sort a gti rear beam too Wishes for more power...
20-08-2016, 05:33 AM
Doh. Not what was needed.
Pull into fuel station. Fill up. Pay. Hit the go button, bam. Lights out. Push it away. Start checking stuff... Get ignition sometimes, other times not, faded lights. Clicks. Battery not all that old. Connections good and indicator is green. Assume barrel is defo dead. But i'm in a suit, with wife in dress, an hour from home. Recovery time. 1hr 50min later. He arrives. Battery is dead. The indicator is kind of blown/cracked...so assume a cell went pop in the second I turned ignition on. £74.99 later...I'm away. Ouchy. Wishes for more power...
20-08-2016, 08:49 AM
are those hid's sucking too much juice?
It goes, it stops (as reqd).
Hate Housework!
20-08-2016, 06:13 PM
(20-08-2016, 08:49 AM)Magenta Sunset Wrote: are those hid's sucking too much juice? I don't run hateful hids!? Wishes for more power...
20-08-2016, 06:34 PM
Think he meant HDI's didnt you magenta... thank me later for covering your ass
23-08-2016, 06:14 AM
No indication of the battery giving up before now? Very strange that it should just give up like that, might want to look for a cause - alternator charging ok, earths and power cables good?
23-08-2016, 06:39 AM
(23-08-2016, 06:14 AM)Poodle Wrote: No indication of the battery giving up before now? Very strange that it should just give up like that, might want to look for a cause - alternator charging ok, earths and power cables good? Yeah, random, no battery issues at all...only thing is ignition barrel being on last legs so need to do that this week Wishes for more power...
23-08-2016, 08:12 AM
I'm sure that ignition barrel has been dodgy for 6 months now!?
23-08-2016, 08:49 AM
(23-08-2016, 08:12 AM)Toms306 Wrote: I'm sure that ignition barrel has been dodgy for 6 months now!? Pretty much Had the replacement since Pugfest sat on the shelf... But y'know... #ratherworkonsomethingfun Wishes for more power...
02-09-2016, 03:05 PM
So insurance have written this off. Cat D.
But its very cheap buy back and not a bad price given so...guna take that and get it repaired at mickeys and get ding which was there when we bought it done too... Or it all goes on Kev! Lol Wishes for more power...
02-09-2016, 03:29 PM
(20-08-2016, 06:34 PM)MY95 Wrote: Think he meant HDI's didnt you magenta... thank me later for covering your ass spandex or leather?
Hate Housework!
02-09-2016, 04:36 PM
give adam a shout if you want bits, he found more rust on that 206 he bought...
02-09-2016, 07:01 PM
(02-09-2016, 04:36 PM)welshpug Wrote: give adam a shout if you want bits, he found more rust on that 206 he bought... Yeah he has messaged on Piggypower... Trying to match up who Adam is though now Wishes for more power...
26-12-2016, 09:15 PM
This poor thing keeps getting bashed....
So need a bonnet now. Was tempted by an identical spec but clean/dent free 206 in glocs for part reshell couple weeks back...even more tempting now. Pfft. Flipping things. Put a new bottom pulley on this evening...old one was beginning to do a worrying rattle Also due a service end of this week...cant believe done another 10k in it. Wishes for more power...
26-12-2016, 10:15 PM
It's great that the old girl is still motoring on, amazing what they'll do with sensible maintenance.
26-12-2016, 10:26 PM
(26-12-2016, 10:15 PM)Dum-Dum Wrote: It's great that the old girl is still motoring on, amazing what they'll do with sensible maintenance. I need to check but think we've done 40k in it now. Only breakdown being a puncture and the battery. Wishes for more power...
27-12-2016, 09:50 AM
(26-12-2016, 10:26 PM)Piggy Wrote:(26-12-2016, 10:15 PM)Dum-Dum Wrote: It's great that the old girl is still motoring on, amazing what they'll do with sensible maintenance. is this a pre CAN version like our 206 we have had ours now for 5 years and like you say regular oil filters a battery, droplinks,wishbone and an exhaust not an expensive car to run at all to run and still going strong https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
27-12-2016, 05:44 PM
Yup early one. I've contacted the one in Glocs. May make a cheeky offer.
Do a swap over of all the good bits and flog this one cheap. Wishes for more power...
14-01-2017, 05:32 PM
Just sums up my ruddy week.
Hit n run in carpark Driver even had the decency to get out, rub the dent and then drive off. I'd show you the dent in the 206 but the uploader still doesnt work. Wishes for more power...
