28-07-2012, 11:08 AM
or a whole key and lock and immob. ring set? I've seen some on Ebay..
Why can't I leave?
28-07-2012, 11:14 AM
Hmm that sounds like hassle. I know of a Citroen specialist in the next town who have the equipment, wonder what they'd charge...
28-07-2012, 12:07 PM
£ra*e.99 and you pay for the vaseline.
28-07-2012, 09:34 PM
Hmm, from what I can work out you need a brand new key and then reprogram it. That sounds a little expensive. So a phase 3 key can't be reprogrammed basically?
![]() Will just have to be very careful with the key I've got! Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
28-07-2012, 10:13 PM
Tbh, I'd get another cut with no immob chip just incase you lock your keys in the car....atleast you can get in then, although not start the engine obv.
29-07-2012, 09:16 AM
It comes with one key/chip/remote thing and one key without the buttons, so I already have a spare. The key buttons look knackered though so I was trying to work out whether I needed a brand new key/transponder or if Niall could wipe and re-write a second hand key with his fancy software...
29-07-2012, 10:41 AM
If its just looking tired, just buy a new case and swap all the gubbins
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
29-07-2012, 01:23 PM
^That...make sure you swap the immob chip lol, seen people forget it several times....
Plus, a second hand key will more than likely have crap buttons anyway lol.
30-07-2012, 09:25 PM
As I type this, there is a 306 parked out my window with my name on it
![]() Boot popper is in the post. I had a hard time convincing people it was ok that I couldn't open the boot on my new car haha! Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
30-07-2012, 09:27 PM
Where's the pics then?
31-07-2012, 07:29 AM
Keys are easy, I had the rallye key "cloned" on the local lock smiths, they cut the blade then put the key in the machine, took it out placed the fresh cut one one and it copied it. I asked him if I need to do anything and he said it will just do exactly the same as the other.
I mainly got it incase I forget an somehow lock my keys in. But as it works I'm using it as the daily key and the original is at home. Cost me £25 ![]() TEAM CONROD SHITTING RALLYE!
31-07-2012, 07:42 AM
(30-07-2012, 09:25 PM)c.a.r. Wrote: As I type this, there is a 306 parked out my window with my name on it Why have you ordered a boot popper? You already have one in the boot for the central locking which is no longer connected to anything as the lock has gone, why don't you just use that? Mine works perfectly!
(31-07-2012, 07:29 AM)Matt Wrote: Keys are easy, I had the rallye key "cloned" on the local lock smiths, they cut the blade then put the key in the machine, took it out placed the fresh cut one one and it copied it. I asked him if I need to do anything and he said it will just do exactly the same as the other. I may need to pay your locksmith a visit then; I don't fancy not having a spare key for mine.... :S
Astor 'X' 4 GTi6-6 - SOLD! ![]() '08 LY Renault Megane RS 230 F1 Team R26 - GONE '56 BMW Z4 Coupe 3.0si Sport - SCHWIIIING!
31-07-2012, 07:45 AM
(31-07-2012, 07:42 AM)Ed Doe Wrote:(31-07-2012, 07:29 AM)Matt Wrote: Keys are easy, I had the rallye key "cloned" on the local lock smiths, they cut the blade then put the key in the machine, took it out placed the fresh cut one one and it copied it. I asked him if I need to do anything and he said it will just do exactly the same as the other. Ed if all you want is a spare to start the car, buy a second hand key off eBay and I'll program it. Just means the RCL won't work on that key.
Ah cool OK, so just a second hand key off of eBay or a breakers should do the trick? They'll just copy my key over?
After my third journey in the car I have a little list of to-do's... 1. Install the boot popper (bits are in the post...) 2. Sort out the passenger high-beam as it doesn't work 3. Sort out the clock / temp display illumination as it comes and goes... 4. Sort out the 'spaztastic' windscreen wipers. I'm pretty sure this is a case of cleaning the contacts? 5. Line the dashboard with something to stop the rattles 6. Dashboard lights, I may look into turning the whole illumination blue to match the boost gauge. One of the bulbs is a bit reluctant to come on sometimes... 7. Convert some of the lights to LEDs Some stuff can wait, whereas the boot opening is kind of important. The last thing I want is a site visit and not be able to get my PPE out of the boot because it won't open. Lolz. Anyone got a spare Haynes kicking about? (31-07-2012, 07:42 AM)mark_airey Wrote: Why have you ordered a boot popper? Oh crap just read this. Really? So I've wasted £8 already?! Bugger. Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
31-07-2012, 08:44 AM
(31-07-2012, 07:49 AM)c.a.r. Wrote: Oh crap just read this. erm, yeah.........lol. you require nothing more than a bicycle spoke to link it to the boot release and some re-wiring to whatever you want to activate it with. Also if you want a PDF copy of the haynes I can send you it tonight if you PM me your e-mail
31-07-2012, 09:13 AM
Aw cheers Marky Mark.
A bicycle spoke you say... Is it possible to wire in a boot popper and retain the rear wiper? I know it's the 'done thing' to remove the rear wiper but I kinda like it. I'll only remove it if I need to... Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
31-07-2012, 09:16 AM
Can you two stop being nice to each other please, its really weird.
31-07-2012, 09:33 AM
(This post was last modified: 31-07-2012, 09:37 AM by mark_airey.)
(31-07-2012, 09:13 AM)c.a.r. Wrote: Aw cheers Marky Mark. yeah, just cut it to length and bend the ends around the hooks on the solenoid and the catch.............you could wire it up however you like TBH, it would just require getting wires into the boot which should be fairly simple to do via the rubber tube thing that all the others are inside! Mine is wired to the rear wiper switch on the stalk as I don't have a wiper so the wiring was there already ![]() (31-07-2012, 09:16 AM)Dan! Wrote: Can you two stop being nice to each other please, its really weird. :ROFL:
31-07-2012, 11:03 AM
31-07-2012, 12:15 PM
Matt, you payed £25 for a key blade? Wtaf?! I had new blades made up for my dt and that cost like 2 quid...
31-07-2012, 12:41 PM
(31-07-2012, 07:45 AM)Niall Wrote: Ed if all you want is a spare to start the car, buy a second hand key off eBay and I'll program it. Just means the RCL won't work on that key. So Niall, I've got 3 keys from my old '6 kicking about still; one skeleton key with no buttons at all, and 2 remote keys, one with no battery. All 3 blades fitmy old '6 though. Can you program the fob to unlock my new car then? Or is it the immobiliser you're reprogramming then? I'm confused? Ideally if you can reprogram the RCL & Immob to my car, then I can get a blade cut and then it'll be a fully functioning spare...? ![]() (31-07-2012, 12:15 PM)Connor Wrote: Matt, you payed £25 for a key blade? Wtaf?! I had new blades made up for my dt and that cost like 2 quid... And following on from that, where'd you get yours cut from then?!
31-07-2012, 12:46 PM
(This post was last modified: 31-07-2012, 12:50 PM by Midnightclub.)
You can get spare blank blades on eBay for like £1 lol they used to be last time i looked anyway
EDIT: Tad more than it used to be but no where near £25 lol http://www.ebay.co.uk/itm/Peugeot-106-20...674wt_1002
31-07-2012, 12:47 PM
Gemsec, not sure if its a national firm though
31-07-2012, 02:45 PM
Anyone know the part numbers for the actual bare key fob (without blade) but with buttons? Mine looks knackered and has no keyring on it as that's broken off..
31-07-2012, 02:52 PM
That eBay link i posted will probably be cheaper than going to pug and it comes with a uncut blade too
31-07-2012, 03:03 PM
OK Pug want £90 odd for a fob case, 2 buttons and the little screw! F That.
Will a fob with the LED hole in it be OK for my phase 3 remote one? As mine doesn't have that LED. As long as the gubbins inside still fits the same... Disclaimer: The above is not to be taken to heart and is probably a joke, grow up you big girl.
31-07-2012, 03:15 PM
Ye will be fine. Buttons are all in the same place. The phase 2 one has a fatter back but should be able to use the phase 3 one anyway I have before
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead
31-07-2012, 03:26 PM
(31-07-2012, 12:41 PM)Ed Doe Wrote:(31-07-2012, 07:45 AM)Niall Wrote: Ed if all you want is a spare to start the car, buy a second hand key off eBay and I'll program it. Just means the RCL won't work on that key. Ed I can program the immobiler but probably not the RCL. Sometimes it works but more often than not it doesn't. Bring them to ace on Saturday and we will have a go. Worst case is you will just have 2 extra keys that start the car (when you get the blade cut of course) and that's it.
31-07-2012, 03:54 PM
(31-07-2012, 03:26 PM)Niall Wrote: Ed I can program the immobiler but probably not the RCL. Sometimes it works but more often than not it doesn't. Ideal, can't complain with that! Cheers buddy, I'll make sure to bring em along
Astor 'X' 4 GTi6-6 - SOLD! ![]() '08 LY Renault Megane RS 230 F1 Team R26 - GONE '56 BMW Z4 Coupe 3.0si Sport - SCHWIIIING! |
| i'll just leave this here for a while - - | Magenta Sunset | 20 | 11,571 |
24-08-2016, 04:40 PM Last Post: Rippthrough |
| Uhh il just leave this here... | Sian | 18 | 11,181 |
08-04-2014, 09:03 PM Last Post: devils_fuel |
| two weeks gardening leave before I start my new job, what to UPDATED | swampy | 13 | 8,158 |
25-06-2012, 09:27 PM Last Post: ash240970 |
