idle and constant speed problem getting worse
#31
(30-07-2012, 06:08 PM)lewisdmz Wrote: Have you unplugged the power steering sensor from between the inlet manifold and the rad? Known for these to cause funny issues?
I think this was suggested recently in a different thread can't remember if it was you or not?
i did read the thread and tried it, didnt make any difference Sad
#32
Cracked resonator under the manifold? What's your mpg like?
[Image: sigjpg.jpg]
Serious.
#33
how would i check for a cracked resonator without removing the manifold? would brake cleaner/easy start find it and raise engine speed?
ive only gone through 2 tanks, 30mpg and 33 mpg measured over each one, brim to brim method.
#34
As above and you may aswell just remove the manifold to check it and replace inlet and throttle body gasket while you are at it. Wink
#35
wouldnt that make the idle fluctuate quite a bit?
mine stays more or less constant, just really rough after a few mins.
is it a bugger to get off?
edit: wouldnt it have done anything when i covered the whole area with brake cleaner?
#36
so today i disconnected the lambda sensor completely, it made no difference at all to how it ran (that i could tell anyway)
didnt even bring the EML on.
#37
Lambda will only bring up a EML if it goes well out of range.
You need to check the condition of the lambda wiring and also get a new temp sensor bunged in there.
#38
ive replaced the coolant temp sensor if thats what you mean bud.
where would i find the values? im going to test at the sensor, at the plug and as close to the ecu as i can get.
the lambda wiring looks ok tbh, from what i can get to anyway.
#39
Not sure about the voltage values from the coolant temp sensor.
Wiring might look ok but might not be. Break in the wire or corrosion can cause all sorts of problems. Don't forget any added resistance from the wiring and plugs will mess up the final reading reaching the ECU.
Tried any injector cleaner through it? Could be a iffy or dirty injector.
#40
yeah i dumped a bottle of millers through, as of yet no joy.
ive unplugged the injectors one by one and all made it as bad as each other. also measured the resistance of the injectors at the plug and theyre within tolerance.
#41
There's no way you would get 30mpg if the lambda was broken/not reporting.
[Image: sigjpg.jpg]
Serious.
#42
there were a few long runs in there mate constant 60mph the whole way.
i disconnected the lambda sensor completely today, no change. zip. nothing.
so looks like a wiring or ecu fault now.
need to find out where to do a continuity test on the wires. which pins on the ecu plug would i need?
is there any way to test the ecu itself?
#43
continuity tested from the plug to the ecu plug and all beeped Sad
#44
annnd another part replaced and no cigar Sad
crank sensor Sad
#45
Have you changed the intake air temp sensor Karl?? The little grey one on the throttle body......
#46
i havent replaced it, but unplugging it had not effect at all
#47
Tried replacing coil packs?
They're renound for going on GTis - lift the coil cover and have a look, if there's hairline cracks in htem, that's probably the issue....
#48
replaced them already bud.
something else happened today, was going through the gears on an A road and suddenly lost all power like the engine died. put the clutch in to coast to the side of the road and noticed the rev gauge stopped at idle speed, put the clutch back out and it drove ok using light throttle.
now thinking fuel pump Sad
got one on its way
#49
are there any other things that anyone can think of that would cause what is happening? seems really weird because it doesnt fit the pattern of alot of other threads tbh...
#50
Fuel pump in, no difference
#51
looks like the cause was a f*cked up wiring bodge. a load of the cables for the sensors were broken and just twisted together. got the wiring sorted fired it up and it idles sweeter than ive seen it before.
aparently these are all a little bit ropey and have the occasional "rock" here and there but its nowhere near as bad as it was
#52
Well look at it this way, at least you won't have to replace anything any time soon!
#53
spokje too soon., went back to how it was before a few hours later.....and not holding out much hope tbh, i dont have alot of luck with 306's haha
#54
now had a complete engine bay wiring loom, still doing it.
now im totally out of ideas
#55
fitted a set of injectors today and it fine now.
the 4 i took off of the car, the numbers didnt even match each other let alone the ones i put in
#56
Odd that it's only just showed up but glad you've sorted it. We're they all green injectors?
#57
problem back again i spoke too soon.
the plug bit is green yeah, but the numbers were different and one had a black injector body
#58
Gti injectors are green bodied as far as I remember.
#59
think we may have got to the bottom of it.
the fpr on it is 4 bar.
according to 6 forum and service box it should be a 3 bar
#60
I put a 4bar one on my 6 to improve the fuel flow... Can't be that, unless the 4bar one is knackered....! Huh
[Image: Sig3_zpscd005eb1.jpg]
Exclamation High idle problem! PugRory 5 3,870 30-05-2014, 06:00 PM
Last Post: Niall
  SOLVED:Idle Problem Eeyore 77 37,158 03-05-2012, 08:36 PM
Last Post: Toms306
