23-10-2015, 11:27 AM
Think its worth changing the master cylinder then? Its on its original one from the factory as far as I know.
Checked and seems fine from the engine bay
Where to find new front brake callipers quite cheap?
25-10-2015, 04:36 PM
Sounds like you'd be better off taking it to a garage. I'd be amazed if it's much more than a half hour job to sort it. Sliders stuck or pads stuck would be my first suggestion, failing that it'll probably be the pistons.
| Which callipers will fit under my c5 "steelies?" | Xsikid | 6 | 6,632 |
05-06-2017, 04:42 PM Last Post: Xsikid |
| Disconnecting rear brake lines at the front | Iaitoo | 21 | 11,010 |
04-06-2016, 08:22 AM Last Post: pug306driver |
| New Cheap Front Lucas Calliper Suggestions | MY95 | 4 | 3,042 |
19-04-2015, 01:40 PM Last Post: titch |
