Car Broke Down, Suspect Headgasket
#31
I would try a new or second hand know to work ICV first.
check earths too.
it may have just started getting warm coz it was running rich and revving its nuts off
Or to add to piggys idea blast the icv out with brake cleaner
as he said in the first post, he has already done that.
so Im suspecting its totally kaput
Skim reading fail
Well I changed the throttle cable and cable housing last weekend. Took me a while but did it myself. Also removed the throttle body and cleaned with carb cleaner and replaced the Idle Control Valve, Postion Sensor and RPM Sensor and crank shaft sensor. Throttle cable seems like a dream now and car idles ok but I still have the intermittent problem with the rev counter which stops working.
I will post another thread about that as I don't think its head gasket related
Chris
mine used to do this dont know what the problem was then the headgasket went around 10k later, dont know if it was related or not?
I've had a few TU engined cars. Both have had a film of oil in the rad, but no other indication of head gasket failure. I changed the HG on the 106, and there was no difference. After this, I concluded that a bit of oil was normal for these cars.
Check for pressurised coolant pipes when running - that's when you know it's gone.
No oil is normal for any car. There's no oil in my rad.
  Headgasket refitting Toms306 6 4,028 30-04-2016, 02:21 PM
Last Post: Alan_M
