Worn master cylinder seals (pics)
#31
Check the caps seal, it could be letting water or moisture in.
As said 5.1 is the best to use, it contains silicone so it won't absorb moisture as much and work well when heated up from hard brake use. Just flush the whole system with it and chuck it away then refill it all again with 5.1.
#32
And?
Means nothing, the motor factors might have had it years, what's the date on the bottle?
#33
Couldn't find a date? Just what looked like a time stamp and a code above it.
  Worn Diff and how to know what gearbox’s what? Rob Mudhouse 13 8,152 17-03-2021, 01:09 PM
Last Post: Rob Mudhouse
  HDi 23.8mm Master Cylinder - Where from? Alan_M 3 3,295 07-09-2016, 02:33 PM
Last Post: Alan_M
  Handling on a worn out rear beam? JTaylor2005 11 7,626 10-08-2015, 04:26 PM
Last Post: JTaylor2005
