l/h/side earth point
car virtually mot ready, so today ( dry and sunny but cold, so an excellent day here ) checked on cabin earth points at the front, found the drivers side one, large as life and all good, but where the hell is the one on the left hand side??
took the lower trim kick panel off and found the heater motor and its drain pipe, along with possibly the a/c pipes and drain, but just could not find the earth point.
carpets and foam all dry so no water leaks from scuttle/bulkhead area, thank god, just thru the door speaker, which has been "repaired" sod pug parts with the door seal sheet at £39 plus vat!! duck tape and blue dpc blue plastic.
where is the l/h/side front cabin earth point please?
[Image: earthpoints.jpg]
GTI6 Info
Thanks cully, found all apart from 5 and 6, not looked for them yet, but wtf is 10?? similar place to 9 by the bonnet release handle, easy to see and large as life, or well hidden under some trim???  I have peeled back the carpet but just cannot see an earth point in that area.
  Earth locations pug306driver 2 852 22-01-2022, 04:19 PM
Last Post: pug306driver
Rainbow Gearbox earth connection part FIXED Welshy_Pete 7 2,427 22-05-2016, 06:29 PM
Last Post: P-Courty
  Earth lead Niall 0 919 07-12-2014, 04:05 PM
Last Post: Niall
