Brake pipe flaring
Brake pipe flaring
Smile
Hi quick question I am making up some brake pipe to replace the stuff at the rear of my rallye
Am I correct that any Union with a 'male' fitting I.e. Into the caliper
Is a single flare and any 'female' fittings are double flares?
Alan
On the whole that's true but not always.
Is there a diagram anywhere of what pipes require what flare?
No what you need to look at is where the pipe is fitting I to and put the opposite on the pipe
Makes sense
  Brake pipe failure Mighty306 3 1,779 15-08-2020, 03:27 PM
Last Post: ekjdm14
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 6,992 18-04-2019, 10:14 AM
Last Post: Mighty306
  Plastic brake pipe clips Mighty306 3 2,208 12-04-2018, 01:25 PM
