Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
09-10-2014, 03:19 PM
(This post was last modified: 09-10-2014, 03:22 PM by silverzx.)
Only able to get the outside 4 bolts out of 5 on my downpipe adapter plate nipped up, the middle one has no chance of getting a nut over the stud.
It's all Fire-Gummed up, cross fingers and hope for the best?
OR any suggestions?
Picture:
09-10-2014, 03:57 PM
(This post was last modified: 09-10-2014, 03:58 PM by Piggy.)
Remove stud and use a bolt with a allen key head?
(whats with the gap of weld behind that stud!?
Threads: 11
09-10-2014, 04:41 PM
(This post was last modified: 09-10-2014, 04:42 PM by vincent1.)
will it also be ok with the missing weld under the stud?
edit!!! beat to the question by piggy
Threads: 266
18
It's welded on the inside smart arses.
Threads: 169
91
09-10-2014, 05:16 PM
(This post was last modified: 09-10-2014, 05:16 PM by Grant.)
On a completely un-related note; how did you get on mig'ing those v-band collars on? Did they warp at all? They look like they've had a fair whack of heat through them.
Threads: 465
114
Car Model/Spec: Vauxhall
looks like TIG to me
Threads: 122
9
Thats not tig, looks very nicely welded though
Threads: 266
18
Was gonna be TIG but ended up being MIG done by a skilled welder.
Threads: 169
91
Was gonna say, it's a bloody tidy mig! It's all gone on nice then? Obviously it's a continuous weld, so no troubles with warping and sealing on the v-band etc?
Threads: 266
18
She's tight. [THUMBS UP SIGN]
Obviously no leaks or anything!
Thats a fairly large gap between the two other fixing bolts.
My bet would be once under stress and heat that it will blow there.
As i said,can you remove stud and use a bolt with a narrow head, IE a high tensile allen head bolt?
Threads: 266
18
(10-10-2014, 07:27 AM)Piggy Wrote: Thats a fairly large gap between the two other fixing bolts.
Probs, I'll see what I can get my hands on later.
Threads: 266
18
10-10-2014, 01:42 PM
(This post was last modified: 10-10-2014, 01:42 PM by silverzx.)
Sorted.
Threads: 266
18
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Come on, rep for telling the lad to put a bolt in the hole he needs tightening up? Trent, you'd used the exact same allen headed bolt right next to it, what are you like eh? :p
Take it back out and weld her up I say
No harm in asking!?
It solved the issue didnt it!?
Threads: 41
Car Model/Spec: Dtractor
Given 6 thank(s) in 6 post(s)
Personnel I wouldn't worry, you're downstream of the turbo so if you have a decent flowing exhaust there shouldn't be much pressure there anyway, and if there is a little seeapage it's not going to make too much difference. Mines been on with just 2 before, and gum and the free flowing exhaust didnt have enough back pressure to make it fail
