02-02-2013, 07:12 PM
o.k, the lock is knackered on my glove box and ive had to use a screw to keep the dam thing closed.
what options have i got?
glovebox removal
02-02-2013, 07:24 PM
Ive always broken mine when ive tried removing it in the past!
02-02-2013, 08:01 PM
(This post was last modified: 02-02-2013, 08:02 PM by 4WayDiablo.)
Hammer.... Bug hammer!
Nah he proper was is to tsp the pins out the hinge at the bottom buts so much easier said than do s
02-02-2013, 08:19 PM
so its not a dash out job then. does this mean that i will have a seperate key aswell.
02-02-2013, 09:16 PM
thats an interesting question... i presume you would have a seperate key unless you can swap the internals.
02-02-2013, 10:17 PM
Iirc you can swap the locks with a heat gun by splitting the two parts of the glovebox pita and pointy nose pliers to get the pins out mega easy just need to lie on your back in the foot well
02-02-2013, 10:25 PM
(02-02-2013, 10:17 PM)spike2002 Wrote: Iirc you can swap the locks with a heat gun by splitting the two parts of the glovebox pita and pointy nose pliers to get the pins out mega easy just need to lie on your back in the foot well He's used to lieing on his back!
The glovebox door is helt on by 2 plastic pegs on the bottom remove the carpeted part of trim underneath and there easyish to get at. Then the lock can be taken apart with a flathead screwdriver so the lock internal can be removed and swapped into a new lock. I did this myself afew years back so not 100% on each step but its not very hard. Trickyist part was getting the spring to stay still on the lock so it springs back when you turn it to open
TD04 11mm Sedan, now 2.1 vnt
Sedan Project http://306oc.co.uk/forum/thread-5763.html Provence Dturbo Dead Blaze 1.6 Dead China 5dr '6 Death by cambelt failure Matt White HDI estate Death by wiring Sedan Dturbo aka triggers broom Diablo estate Dturbo Living dead
02-02-2013, 10:37 PM
(02-02-2013, 10:25 PM)HDIkyle Wrote: The glovebox door is helt on by 2 plastic pegs on the bottom remove the carpeted part of trim underneath and there easyish to get at. Then the lock can be taken apart with a flathead screwdriver so the lock internal can be removed and swapped into a new lock. I did this myself afew years back so not 100% on each step but its not very hard. Trickyist part was getting the spring to stay still on the lock so it springs back when you turn it to open dont sound to hard that. i gather the scrappers is the best place for a lock then or can i get a new one from pug? should imagain they would be to expensive.
02-02-2013, 10:47 PM
(02-02-2013, 10:37 PM)kingy Wrote:(02-02-2013, 10:25 PM)HDIkyle Wrote: The glovebox door is helt on by 2 plastic pegs on the bottom remove the carpeted part of trim underneath and there easyish to get at. Then the lock can be taken apart with a flathead screwdriver so the lock internal can be removed and swapped into a new lock. I did this myself afew years back so not 100% on each step but its not very hard. Trickyist part was getting the spring to stay still on the lock so it springs back when you turn it to open I'm gotta go loomseys one day mate so if you fancy meeting me there one day
03-02-2013, 08:50 AM
(02-02-2013, 10:47 PM)kentiiboii Wrote:(02-02-2013, 10:37 PM)kingy Wrote:(02-02-2013, 10:25 PM)HDIkyle Wrote: The glovebox door is helt on by 2 plastic pegs on the bottom remove the carpeted part of trim underneath and there easyish to get at. Then the lock can be taken apart with a flathead screwdriver so the lock internal can be removed and swapped into a new lock. I did this myself afew years back so not 100% on each step but its not very hard. Trickyist part was getting the spring to stay still on the lock so it springs back when you turn it to open can do mate, will have to be sat or sun cause of work.
08-02-2013, 08:57 AM
I hade also problem with the glovbox, i couldnt find a new one or a used one so i toke off the glovbox (under there are 2 plastic pins) difficult to get off but would work,
next i used a hot flame tourch to make it open on front off the glovbox about 10/15 cm/4 inch inwords and melt it open all the way be carefull not to do it not to close, iff you have make it open there are 2 springs that need to strech out, put it back again and hot the knife to make smooth service as possible, and the glovebox is repaired. Reason for not closing (spring to soft need to stretch them wide open) good luck Sorry bad English Norway here.
08-02-2013, 12:30 PM
It is very cold -20 but here is a movie about glovebox repair removal brrr.....cold
Glovebox hell(p) | turkish | 4 | 1,212 |
31-03-2014, 05:26 PM Last Post: Frosty |
Glovebox locked itself ..!! | Masonsmummy11 | 16 | 2,205 |
27-03-2014, 12:43 PM Last Post: Masonsmummy11 |
how do i remove my glovebox from my gti-6?? | hodgie | 4 | 2,633 |
11-07-2012, 03:26 PM Last Post: darrenjlobb |
