Threads: 53
6
Car Model/Spec: XRdt.
Afternoon guys,
Samass pointed out to me earlier that my O/S CV gaiter has decided to lose it's retaining clip, and as such has probably lost most of it's grease. It's not actually split by the looks of it so hopefully the joint is still in fine condition.
Does anyone have experience with replacing the gaiters? As far as I can tell it should be just taking the hub off, getting the caliper out of the way, cutting the old gaiter off and somehow getting a new one on...
Do those kits with the cone device work well?
Cheers guys for any input.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
03-07-2012, 04:24 PM
(This post was last modified: 03-07-2012, 04:25 PM by zx_volcane.)
regrease and reseal with a new clip or at a push zip ties
otherwise, hub off, split the cv joint, take the old gaiter off and refit new
or use a stretchy one and you won't have to split the cv
and there are different sizes i think depending on shaft thickness (oor errr)
Threads: 376
38
Car Model/Spec: Phase 1 GTI 6
Pah! Have fun with the one Toby!!
On a less trolling note, I your changing the boot, you might want to consider the 'cone' tool, literally makes the boot slip on like a glove!
Phaes 1 GTI 6 - Onyx Black
Threads: 127
33
really though if it isn't split, just re-grease it and put a new clip on
Threads: 376
38
....I'm going to split it and watch you get greasy
Threads: 59
Car Model/Spec: 306 D-turbo
I hate changing the boots on these all the little annoying rolling pins. In your case repack with grease and get a clip or a thick cable tie.
Threads: 130
82
Car Model/Spec: 106 GO-NAD
Dude, it is split. You just cant tell cuz of the derv filth. The clip is still on the shaft, but the rubbers f*cked. I did tell you this, y u no listen???
