hi spec 4 pots again
http://www.ebay.co.uk/itm/Hi-Spec-Motors...2a1f7c0e35
It may just be me, but for 285mm discs it hardly seems worth it. I'd rather spend the money on a new set of discs and 1144s or DS2500s
Thanks mark Smile will be watching as they are just up the road from me Big Grin could i use my drilled and grooved gti discs with these?
You can use these with 6 discs. And these stop much better than and 6 set up I have had.
Cool. Ima keep an eye on it. What pads would you recomed for these?
Also is the master cylinder man enough for these?
I have used Mintex 1144 and 1155 I will post a link for them on camskill later as on mobile now.
Anyone who has been in my car will know how good these are.
i've heard these stop lock ups....
Cool thanks. Will have a little look around later as im on my phone aswell lol. Quite like the sound of these . Just hope i can get them under cyclones with a resonable spacer.
IIRC dint you run a 10mm on cyclones? Was there any arch mods?
I did have 10mm and cyclones. Not arch work. You could always roll the lip if you need a bit of space.
Didnt really want to do that either , take it you didnt then?
http://www.camskill.co.uk/m33b0s3403p277...rake_Pads_
Na the fronts I did for the borbets
  Wanted: 205 pepper pots wanted bashbarnard 4 2,457 27-02-2017, 06:29 AM
Last Post: bashbarnard
