front seatbelt
front seatbelt
Had a dumb moment today, found a 306 with black A B C pillars, but couldn't get the B pillar plastic off because I couldn't work out how to first unbolt the seatbelt Blush
Anyone to explain how to get them off?..
GT2052s DTurbo
OEM+ HDI Estate
Project thread
The bit you pull out to adjust the height of the seat belt you just pull it off and there is a screw under that. Then there is a 17mm bolt that holds the seat belt you undo then the main but just pulls out as its just clipped in
  Seatbelt stuck HDIkyle 8 3,849 18-02-2014, 05:29 PM
Last Post: HDIkyle
