306 Driveshafts
Im looking for a passenger side drive shaft for my phase 1 dturbo, is there differences in the other phases/models? Thanks
I need an answer as fast as possible as i want to buy one today Smile Sorry for the quick bump!
should be the same as all XU engined cars. (1.8, 2.0 xsi, 2.0 gti, 1.9d, 1.9DT)
Rang a scrappy and he told me there is a different amount of splines between phase one and phase 2? Is this true?
that, i couldn't tell you. but i didn't think there was as all the gearboxes are interchangeable, i think.
Thats a good point actually.. You dont need to change drive shafts when putting on a hdi box so they have to be the same........ Anyone confirm this Tongue
all xu are same fitment. has your car abs though?
need one of an abs car if you do iirc
could always get a lift to the scrappy, and take your old one with you. then just compare them
No dont think it has abs.. Ill check now Smile Ill do that samass Smile
Only difference I know of is the ABS sensor ring being present or not!
Team Orange Engine Bay
short shaft youre looking for?
id say i have one off an abs xsara here if youre stuck
infact think i have a few different ones in the shed but i cant currently get in it :/
ah yeah, good point sweeny, abs! easy to check, just look for a pumpy looking thing with lots of brake lines going into it at the front of the passenger side chassis leg in the engine bay, behind the headlight
Thanks sweeney i was only up your way yesterday too for the rally lol Think i have one sorted.. If i put a non abs shaft into one with abs what would happen? Just not click into place?
Nope no abs Smile
my way? im not from donegal?
didnt think there was a rally in cavan :$
If you dd that id imagine the abs wouldnt work Wink
I came from carlow heading for donegal Smile Good point lol
Can i make an abs driveshaft fit one without and how do i do it Smile
  DW8 into 205 Driveshafts/gbox problems? 089 4 3,912 27-03-2015, 07:03 PM
Last Post: 89
  205 Xud9 conversion - driveshafts rd070707 3 2,562 20-10-2014, 01:42 AM
Last Post: Sambarker
