	Threads: 36
2 Thanks: 0Given 0 thank(s) in 0 post(s)
		After blowing the T2, i set about fitting a K14. It's from a Xantia DHY, that has been lying around for fk knows how long.
Anyway, the K14 is impossible to turn by hand. It can be turned using a spanner though, but is still tight as hell! NO play what so ever laterally or in/out (end float). Fitted it partially onto the car - just connected it and exhaust manifold and have left off the inlet manifold to start up the car and to check if it spins up at all. NOTHING, doesn't spin up even when rev'd
The t2/gt15 used to flow shit loads of air on idle. I can't connect up the inlet manifold yet because i don't have the correct piping available to connect the turbo to the intercooler (The Xantia K14 has a flange for the cold side exit)...
Should i just leave mine idling for a while to see if it frees up with use?? Seems the logical thing to do even if it smokes out my garage..
	Threads: 9
19 Location: Northwest (Cumbria)
 Thanks: 0Given 3 thank(s) in 1 post(s)
		Sorry to be the bearer of bad news and all but it sounds like it is fecked, it should spin really freely, if you can't turn it by hand then the bearings are totally shot..............
 Time for another replacement turbo mate sorry.........
	Threads: 87
31 Thanks: 0Given 1 thank(s) in 1 post(s)
		Very fecked, I think thats beyond repair mate, I wouldnt bother wasting your diesel/time...
	Threads: 171
46 Location: Portsmouth
	Threads: 9
		I still can't believe however that it got all the way onto the car before you noticed this    hock:
Normally the first thing I do without thinking if I have a turbo in my hands is spin the shaft
	Threads: 36
		mark_airey Wrote:I still can't believe however that it got all the way onto the car before you noticed this   hock:
Of course i spun the shaft...
Refer back to this thread. Post 12
 http://www.theywhoshallnotbenamed/forum/showthread. ... highlight=
Anway, It does not take long to put on a few manifold bolts to hook the turbo up. This way, I could satisfy myself it was fked before bining it.
	Threads: 9
		n0v0s Wrote:Of course i spun the shaft...
I know how long it takes to fit a turbo  :roll:
but if it doesn't spin by hand its pretty obvious that it is fecked no?!
	Threads: 36
		Whats with the rolling eyes?
 I've only fitted the exhaust manifold/lines. I thought it was fked as it didn't spin. Asked on theywhoshallnotbenamed, was then informed by a few that it may free up with use and considering Darrens probs come accross quite a few k14's, i thought it was worth 30mins of effort to see. You may not have bothered (and probs right to do so), i did.
	Threads: 9
		n0v0s Wrote:Whats with the rolling eyes?
What this thread that only 2 people have replied to?
http://www.theywhoshallnotbenamed/forum/...135189-K14
there is no point in lying about it
You seriously need to chill a bit mate! I'm only trying to help, as Matt said in the above thread, if you can't turn it by hand then what chance do the exhaust gasses have?
	Threads: 87
		Think he means this thread, for some reason I remember it when he posted it, was a while back though   http://www.theywhoshallnotbenamed/forum/...highlight=
	Threads: 9
		Dan! Wrote:Think he means this thread, for some reason I remember it when he posted it, was a while back though
Ahhhh..............but still, advice from Gasgasrob.........ROFL
I don't think by tight Darren would have ment "unable to turn by hand though" as how are the exhaust gasses supposed to turn it to free it up?
	Threads: 36
		   cheers Dan, thats what i meant to post, half asleep
Haah, i'm not too clued up about gasgasrob Mark? But i suppose you're right about that bud. I just hoped Darren meant it would free up if its been sat for a while by ragin it.
I got the engine it came off. So can't be a lube failure. Seems fine but could have sat for aaages. Either way, back to gt15 it is, cheers guys.
	Threads: 9
		n0v0s Wrote: cheers Dan, thats what i meant to post, half asleep
We shall leave that subject for now!
I'm sure I have a K14 at home if you want me to have a look??
Its prob been sat a while if thats the case then yeah mate.
	Threads: 36
	Threads: 9
		n0v0s Wrote:You mean thats why its siezed or do you mean that it could be freed if its been sat mate? Haha can you sense my optimism?!
 Yeaah that would be much appreciated if you could check please bud.
I mean that could be why its seized    I wouldn't use it but I admire your optimism
I might even have a T2 lying around also but I might be wrong......
	Threads: 29
4 Thanks: 0Given 0 thank(s) in 0 post(s)
		I'd beg to differ that it's a duff turbo.
 The oil oil that would of been sat in the turbo from when the last car would of mainly drained away. I think you should make sure there's nice fresh oil in the turbo, and turn it by hand and see if it free's up after a while. They usually become stiff when they've sat.
 When you fit a turbo you're also supposed to crank the engine over for two 30 second blasts to prime up the oil lines and get oil flowing through the turbo before first use.
	Threads: 36
		I've managed to get a ratchet on the shaft, and it's become much easier to spin. Would assume that's because the bearings been allowed to soak in oil.
Going to see if it frees up anymore tomorrow, if it does then might just take a punt
	Threads: 59
3 Location: Gillingham Kent
 Car Model/Spec: 306 D-turbo
		I reckon that it wiull be fine my t2 had the same problem used almost a full can of wd40 down the shaft left it overnight and kept spinning it the it freed itself
	Threads: 9
		n0v0s Wrote:I've managed to get a ratchet on the shaft, and it's become much easier to spin. Would assume that's because the bearings been allowed to soak in oil.
I would see what happens then, Its a mare of a job when its all back together and I wouldn't be able to trust it if it had been seized up!
I didn't get chance to look for turbo's last night, will do it tonight as I will be in workshop for a bit
	Threads: 36
		Kl, cheers Mark.
Checked again this morn, and it's free'd it self to the point where i can just about spin the shaft with my finger yanking up on the blade
I think the bearings just coked in all old oil. My gt15 doesn't look healthy at all so i reckon that'd shit itself and i've got fkin exams looming so no doubt it'd die just befre knowing my luck. If the k14 can last till July, i'd be happy as it's going to be retired then.
Jtrigga, my t2 was a bit tight to turn too when i put it in, now completely  free when took off.
	Threads: 36
		It works!
Boosting 13psi for now on the standard wastegate setting, just need to tweak the mbc and alls a go gooo! Response is similiar to the t2. SUCCESS!
	Threads: 13
4 Location: I wish i knew.
 Car Model/Spec: 306 Rallye // Saab 9-3 Aero.
 Thanks: 2Given 1 thank(s) in 1 post(s)
		De wastegate it, take it out and rag the tits off it then stand and laugh hysterically at your engine running away as the shaft snaps and the engine feeds on its own oil... muhahahahahahaha
	Threads: 17
0 Location: Romania
 Car Model/Spec: 306 Sedan PH1 XUD7TE Dturbo
		My k14 lasted 2 weeks at 23psi and tmic
	Threads: 87
48 Location: South Yorks.
     Thanks: 2Given 74 thank(s) in 70 post(s)
		SonnyRoby Wrote:My k14 lasted 2 weeks at 23psi and tmic  mine's been going a good 6-8 months or so at that psi . . . .
	Threads: 36
		My de-wastegated t2 was going ok for 2months at 28psi. I then adjusted the max throttle arm stop to get it to 30psi... shat itself later that day
Driving it on standardish power yesterday was shocking! Can't believe the difference all my tweaking has made. fkin love the Dturb!
I shall be cooking the k14 upto 30psi later today  :dance:
	Threads: 171
		mine got up to 34 psi at one point but is dow lower now VVV thats been on for about 6 months
	Threads: 36
		Depends on how you drive it and the egts generated. I'm on the motorway quite often hiting wot/ full boost for long periods so i don't think this ones going to last long either.
	Threads: 13
		Mine used to squeel at me at 30psi boost but it never died, until i took it apart to have a see what was involved with the bearings etc. Its pretty dead now!
	Threads: 59
		Mine lasted a almost a year at 24 psi then cranked it up to well over 30psi lasted about 3 days of hard driving and shot itself out the exhaust.
	Threads: 24
		At those PSIs I would be more worried about blowing the gasket or chucking a rod rather than the turbo blowing, which is a relatively small thing in comparison to either of those events.
