06-12-2011, 12:45 PM
Been thinking a lot about reaming the exhaust housing and it's potential uses/benefits and wanted to have a go at it myself. I thought while i was there i might as well make a guide for anyone as clueless as myself. This is specifically for a GT15, no idea if the K03's are similar enough for this to be useful, i would have thought so... The tools you will need:
![[Image: DSC00194.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00194.jpg)
That's pipe grips, 10mm spanner (i've got two there, one's a rathcet jobby cos i'm lazy), 8mm spanner, 8mm socket, 150mm wobble bar, ratchet, hammer. Will also want the all important dremel that i somehow seem to have missed out of the pic... :blink:
Having acquired a gt15 for the princely sum of £35 (absolutely immaculate condition Gareth, thanks again), i decided that yesterday was the perfect day to have go at ruining it. First things first, turbo's are no where near as complex/scary as people seem to think, so don't be afraid to have a go yourself, just make sure all the moving parts are kept very clean. I've never even looked at one that carefully before yesterday, but the whole process took less than 3 hours and that's bearing in mind i'm a bit of a perfectionist (read anal-retentive), so a good hour of that was spent fettling and tidying, probably unnecessarily. Please note if your turbo is still on the car, i would recommend multiplying that time by a factor of ten or so, absolute pig of a job getting them off/on - see hdi power's guide for details lol.
I would recommend taking a few detailed pre-op pictures of the turbo, so you've got something to compare when checking the profile later on. So, take one turbo...
To remove the hotside there are four bolts that need undoing, the turbo needs to be clamped to be able to get the leverage necessary. Be careful of the wastegate arm and oil lines when you clamp her.
![[Image: DSC00184.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00184.jpg)
It's a bit tight in places, so an open ended spanner is recommended (10mm in this case)...
![[Image: DSC00186.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00186.jpg)
When you've undone all four, the two plates they were holding the hotside in place should come away easily...
![[Image: DSC00187.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00187.jpg)
You will also have to somehow deal with the wastegate as it bridges the hot- and cold-sides. I opted to move the turbo in the clamp so i could get to the boost can's bracket and unbolted it from the cold side (8mm socket with knuckle/wobble bar)...
![[Image: DSC00188.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00188.jpg)
and disconnected the boost hose (pipe grips).
![[Image: DSC00192.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00192.jpg)
I would note that doing it like this had the side-effect of leaving the WG flapping around whilst i was trying to work on the outlet, so if you've got a better idea go for it! I just couldn't be bothered to deal with the circlip that secures the arm to the lever, got a history with circlips... :badair:
Now unless you've got a nice shiny turbo (in which case, why the hell are you poking it?), then chances are the hotside will need a bit of persuasion to let go of the cartridge, cue one hammer and a piece of wood...
![[Image: DSC00189.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00189.jpg)
Shouldn't take much, one gentle rap against the ex-mani port had mine spinning freely. Carefully remove the exhaust housing, taking care not to bash the blades of the turbine...
![[Image: DSC00193.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00193.jpg)
Remove the remaining chunk of turbo from the clamp and replace it with the hotside, can have it facing whichever way you want, depends what's easiest for you to work on. A good light source nearby becomes very helpful at this point as this is where you let loose with the grinding head on the dremel, the result...
![[Image: DSC00195.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00195.jpg)
![[Image: DSC00196.jpg]](http://i803.photobucket.com/albums/yy311/acpoodle/Turbo/DSC00196.jpg)
After you've removed almost as much material as you want to, i would stop to check your progress. Thoroughly clean all the metal filings off/out of the exhaust housing and slide it back onto the body of the turbo, just to check that everything is still lining up as it should - ideally you want the gap between the internal face of the housing and the turbine blades to be the same all the way around. Make a note of any areas requiring attention then return it to the clamp to "adjust" as necessary. I actually found it easier to use the coarse sanding head for this, as the grinding head was taking off rather more than i wanted to at the time.
This next part probably isn't necessary, but i did it because i like things to look tidy:
Put the fine sanding head on the dremel and go over your work removing any burrs or bumps, can also take the opportunity to reform (poorly imitate) the progressive edges that existed before you started grinding (this is where you want to be referring to those pictures you took). I also found it a lot easier using the fine sanding head to make any minor adjustments to the shape/curve of the surface to get it just how i wanted. Finally, to get a nice, smooth finish i took the 1200 grit to it, shiny!!
