	Threads: 86
2 Thanks: 0Given 1 thank(s) in 1 post(s)
		from the car?
 Im talking, rear seats, carpets, roof lining, speakers cd player, sound deadening, top and bottom glovebox doors, door cards, pillars..
	Threads: 171
46 Location: Portsmouth
		Door cards. Some have chopped the passenger side of the dash.Single skin the bonnet as they're bloody heavy
 Chris c is selling pollycarb windows. That will save a fair bit
 Then get the hole cutter out and get rid as much as you want inside from the supports
 Slim line fans C5 "steelies" as unsprung weight loss is better so go for some 266 or 283 with decent pads or disks
 The boot lid is really heavy some some epic weight can be saved there
 All I can really think of atm
	Threads: 86
		Sorry post f*cked up, i wanted to know with the list i put up earlier roughly how much weight is there to loose?
	Threads: 171
		Oh right. Erm well I don't really know but at an estimate I'd guess 100kgs
	Threads: 86
		Be doing mine soon, replacing seats and steering wheel too
	Threads: 87
48 Location: South Yorks.
     Thanks: 2Given 74 thank(s) in 70 post(s)
		what you replacing seats for? . .they look smart, it's not as if you track your car or owt' is it? . .
	Threads: 90
54 Location: Cornwall
         Thanks: 0Given 20 thank(s) in 18 post(s)
		Mattcheese31 Wrote:what you replacing seats for? . .they look smart, it's not as if you track your car or owt' is it? . .
Lol ive already said this to him,
I have a pet hate of f*cking buckets / harness's in road cars, makes you look like such a friggin goof imo!
| Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime || #DervMafia |
	Threads: 465
114 Location: Cullompton Devon
 Car Model/Spec: Vauxhall
     Thanks: 1Given 98 thank(s) in 92 post(s)
		lmao! ![[Image: 1%20teeth%20goof.jpg]](http://www.allvisual.ca/web%20ready%20full/1%20teeth%20goof.jpg)
	Threads: 541
124 Location: Aylesbury
 Thanks: 7Given 59 thank(s) in 58 post(s)
		If my memory serves me correctly standard front seats are about 25kg each, fixed buckets and side mounts are 7kg and harnesses are lighter than inertia reels so potentially theres 36kg just in the front seats alone.
 IIRC the weight of the stuff listed above is about 100kg. Door cards are light though and youd have to make up some covers for the inner door anyway so leave them on.
 The carpets and sound deadening are supprisingly heavy. Get a heat gun and a scraper and remove the tar like deadening off the floor under the front seats and youll save a bit.
 Spare wheel and rear wiper are good to remove for weight and once youve stripped it strip the wiring loom back of all the unused wires and youll have a few kgs of wire to weigh in and make some money back.
 I reckon its possible if you went mad to get 200kg out of the car without cutting away metal.
 I did have a list of what stuff weighed but ive lost it. Maybe weigh everything you remove and write a guide.
	Threads: 41
2 Thanks: 0Given 0 thank(s) in 0 post(s)
		I lost 19kg from the carpet alone, surprising how much it all weighs
		And the carpet inevitably holds a feckload of water too... That's a few kilos right there!
	Threads: 448
51 Location: isle of wight
 Thanks: 17Given 18 thank(s) in 18 post(s)
		Go to the gym....?
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg) TEAM CONROD SHITTING RALLYE!
	Threads: 9
19 Location: Northwest (Cumbria)
 Thanks: 0Given 3 thank(s) in 1 post(s)
		Matt Wrote:Go to the gym....?
Have a big shit..........?? that should loose a few KG!
	Threads: 94
0 Thanks: 0Given 0 thank(s) in 0 post(s)
x2
	Threads: 87
31 Thanks: 0Given 1 thank(s) in 1 post(s)
		Why will going to the gym make any difference?!    Padge isnt exactly what I would call fat
	Threads: 94
		Only jokin    Also i cant drive a car without a cd player
	Threads: 465
		dump the aircon and mechanical powersteering pump and the mechanical vac pump
 replace the 2 latter with electric pumps, engine responce will improve equivelent to weight saving
	Threads: 86
		Ye i weigh 10 stone and im 6"1 lol
	Threads: 90
		Yeh get all the carpet / insulation out, as that wont be missed to much if your not fussed by road noise, and weighs a tonne....
	Threads: 87
		Also, look into scraping off all of the cars underseal on the floor/wheelarches etc and just painting it instead. Can save upto 20kg by doing that depending on the size of the car/thickness of the underseal.
	Threads: 136
2 Location: Norwich
 Thanks: 1Given 1 thank(s) in 1 post(s)
		That can't save 20kg?! You wouldn't use 20 litres of underseal to do a car would you? I must of used 1 or 2 to do mine
81 Location: Ipswich
 Thanks: 4Given 104 thank(s) in 102 post(s)
		shotgun your seats if thy are going!
	Threads: 448
		padge Wrote:Ye i weigh 10 stone and im 6"1 lol
Never met you, fair enough haha only having a joke
	Threads: 87
		Ben Wrote:That can't save 20kg?! You wouldn't use 20 litres of underseal to do a car would you? I must of used 1 or 2 to do mine
Remember underseal is thicker than water though, so its not 1kg per 1 litre
2.5L of Waxoyl weighs around 4.5kg according to here - Link
And when you scrape the underseal off you'l realise how thick they apply it from factory, probably alot thicker than you did when you did it. Wouldn't surprise me at all if they used 10L doing the whole underside of a car.
	Threads: 136
2 Location: Norwich
		Hairy muff. Didn't think it would be that much heavier. get scraping then everyone!
87 Location: Suffolk
		Awaits the 'i removed my underseal and now my car has holes in it' threads.
	Threads: 87
		Or not, because I said you should paint it to protect it and 306's are galvanised anyway
		Dan! Wrote:Or not, because I said you should paint it to protect it and 306's are galvanised anyway
They still rust even if they are galvanised....found my mates ph2 had a nice leaky rear arch last week lol...oops.
But yeah I didn't read that, paint would be ok lol.
	Threads: 171
		Toms306 Wrote:Dan! Wrote:Or not, because I said you should paint it to protect it and 306's are galvanised anyway  They still rust even if they are galvanised....found my mates ph2 had a nice leaky rear arch last week lol...oops.
 those leaky rear arces are the exception to a 306 rusting, and sometimes the engine mount cradle lol
		No Peugeots are Galvanized for the record... I was someone who believed they are...
 They are Zinc Phorescent dipped - that's why they don't rust that badly...
 But 306s usually rust in the upper rear arches and just behind the front wheels... If you find the zinc dip hang points, follow the chassis round there, that's where they always fail, just underneath there, but they're usually covered in underseal/plastic/mud/crap so no one ever notices it.
