Threads: 14
Ive had a look but can't find a guide on lowering the rear of the car?
Ive got some springs to drop the front but have been told I just need to adjust the torsion bar on the back to drop it down. Has anyone got any pics or a guide?
Threads: 14
aww silly me haha. Pretty good guide. Whats the "other method"? something to do with clicks?
I want to drop the rear about 60mm which is apparently "2 clicks"?
Threads: 90
Heh yeh it does, entire site does really but never got the time these days, but given its currently advertising theywhoshallnotbenamed, id better make that an active priority!
Threads: 14
ok so I started lowering the back down but couldnt get the torsion bar out of the hub end so it was the notch method for me!
done one side but it was getting a bit late to carry on banging so finishing it off tomorrow!
Once you start, and you get all the bolts out its not so bad. When I've been looking up how to do it lots of people are put off beacuse they are told it can be tricky, but now I've done it I say you may as well try. As if you really do fail just put it all back together and then get someone else to do it haha
