20-04-2012, 12:37 PM
Tapatalk fail.....
Audio Budget - What to get??
Tapatalk fail.....
20-04-2012, 12:39 PM
mark_airey Wrote:ginge191 Wrote:I need sub and amp
20-04-2012, 12:51 PM
mark_airey Wrote:ginge191 Wrote:I need sub and amp to be fair i'll need 2 amps - a main amp for the sub i'll be getting (undecided) and a seperate smaller amp for 2 front components
Phaes 1 GTI 6 - Onyx Black
20-04-2012, 01:26 PM
ginge191 Wrote:to be fair i'll need 2 amps - a main amp for the sub i'll be getting (undecided) and a seperate smaller amp for 2 front components I will send you some pics and info over tonight as to what I have then mate As I say I thought I PM'd you already but clearly I fail
20-04-2012, 02:10 PM
ben87 Wrote:i have a gd cd player for sale £45 posted just bought Kenwood KDC-BT61U ![]() ta anywho
20-04-2012, 07:09 PM
mark_airey Wrote:ginge191 Wrote:I need sub and amp What a gem that is mark that amp is a basslovers must! With phils sub it would be immense!!! PHIL BUY THAT AMP !!!Sorry ginge.... ![]() the smokey old bus that sounds like a tractor...
20-04-2012, 07:23 PM
Just get one of those vibe sub built in amp things they sound sweet anyway dont know why you would need any more
20-04-2012, 07:44 PM
tomw1123 Wrote:Just get one of those vibe sub built in amp things they sound sweet anyway dont know why you would need any more Because unless you spend big £££ on an active sub, the bass is dirty, with no clarity to it, and it just goes booom with no depth to the sound. And rattles your car to hell and back... Edit: Unless you go for a basslink, I've heard these and for what you pay, they are pretty good! ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
20-04-2012, 07:47 PM
Grant Wrote:tomw1123 Wrote:Just get one of those vibe sub built in amp things they sound sweet anyway dont know why you would need any more
20-04-2012, 07:48 PM
Quote fail! lol
20-04-2012, 07:53 PM
Ah f*ck it it can stay like that!
22-04-2012, 10:15 AM
Ok,
So i have found a reasonably priced sub - http://homeavdirect.co.uk/vibe-slick-s15-15-subwoofer But what exactly am i looking at here? I'm looking for a punchy bass, as apposed to the WAARrrrrRRRRblLLeE bass.. Any info on specs which are should be looking at? EDIT: and as for an amp to power the sub, what specifications am i looking for - something to match the peak output? another edit: I've found http://www.caraudiodirect.co.uk/vib-sli ... ass-1.html to amp the sub? suitable?
22-04-2012, 10:54 AM
4WayDiablo Wrote:I'd say go for a 12 inch if you want the punch Wouldn't the bulk of the punch come from the 'enclosure' rather than the sub itself?
22-04-2012, 10:55 AM
Agreed, 10" is pointless if you run decent components amped, can barely make much more bass noticeably. 12" will give added depth and punch in a sealed box, 15" is just overkill for a day to day system.
22-04-2012, 11:08 AM
Toby Wrote:ginge191 Wrote:12" would look quite small, no? what can i say.. . 8-) But no, this is my IOW competition at the moment
22-04-2012, 12:08 PM
12" will be what you want ideally Ginge
![]() The RMS is the figure the sub will output not the peak.. My Hi-Fonics 400w RMS sub is being powered by a Sony 500w RMS amp... As I know I will never play it loud enough to blow it up ![]()
22-04-2012, 12:36 PM
cwspellowe Wrote:Agreed, 10" is pointless if you run decent components amped, can barely make much more bass noticeably. 12" will give added depth and punch in a sealed box, 15" is just overkill for a day to day system. Depends what your after. If your running amped speakers up front with a sub in the back you want the bass on the speaker amp turned down considerably. Otherwise what's the point I having the sub. I've got a 12" (giggedy) and to be fair im not using it to its full potential. A 10" would suffice, but the build looks good with a 12". The speakers upfront are running little bass at all, all I get all the low range from the rear. Until my 3 way components go in that is
22-04-2012, 12:38 PM
Grant Wrote:We all know 4way is bestcwspellowe Wrote:Agreed, 10" is pointless if you run decent components amped, can barely make much more bass noticeably. 12" will give added depth and punch in a sealed box, 15" is just overkill for a day to day system.
22-04-2012, 03:36 PM
Matt Wrote:I have a 12" ported sub box going for free my back seats are where the box will be built ![]() Also, just measured 12 against 15, and the 15 size would fit sweeeeet in the back, i'd like something a bit bigger than your's grant
22-04-2012, 03:52 PM
ginge191 Wrote:i'd like something a bit bigger than your's grant Thats what she said ![]() Thats cool mate, just make sure you have enough depth to clear the sub, mine is about 12mm off the floor lol ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
22-04-2012, 04:00 PM
Grant Wrote:ginge191 Wrote:i'd like something a bit bigger than your's grant thats where your carpentary skills come in handy! I have a plan.. Basically, imagine picturing the car side on: The yellow is a second idea... and maybe build a "new" bench to allow passengers also? ![]() So very similar to yours but a raised section Whatcha reckon?
22-04-2012, 04:05 PM
Cut a hole in the boot and put it in the hole where spare wheel used to be...
22-04-2012, 04:07 PM
The raised section is a good idea, but I would strongly reccomend against/not want anything to do with building the bench lol.
Gets complicated with legality then, obviously. But the raised bit is a good idea, you will probably need a fair bit of fiberglass and some old duvet sheets or table cloth if you are going to do this... This, combined with this should see you through for the moulding of the shape for the sub. Are you going to have amps on show? I also have a power cap here thats yours for a pint should you want it? ![]() Member of the 99% warning or you're nothing club 2000 Moonstone 1.8 Meridian - Sold 2000 China 3dr XS - Dead 1998 Diablo 3dr XSI
4WayDiablo Wrote:Cut a hole in the boot and put it in the hole where spare wheel used to be... my spare wheel is under the car, there is no space there :|
22-04-2012, 04:11 PM
ginge191 Wrote:4WayDiablo Wrote:Cut a hole in the boot and put it in the hole where spare wheel used to be... Take it out Take a trip to the scrappy with a angle grinder and get the holder out of a Clio where they accsess it from inside the car. Use that as the box
![]() TEAM CONROD SHITTING RALLYE! |
| Components/volume/audio things | Tom | 5 | 3,787 |
16-01-2013, 04:28 PM Last Post: Tom |
| audio stalk and new head unit | aaron_one | 6 | 4,016 |
09-05-2012, 09:23 AM Last Post: aaron_one |
| Using OEM audio remote | nauest | 4 | 3,459 |
03-05-2012, 05:24 PM Last Post: ben87 |
