18-12-2018, 10:39 PM
I’ve had a search but can’t find anything..
Has anyone got a pin out or wiring diagram for the glow plug relay please?
Glow plug relay - help please
28-12-2018, 11:45 AM
06-01-2019, 11:38 PM
if you are despret you can use a hdi relay but the dash light will not light up but the glow plugs will
10-01-2019, 10:34 PM
I am very interested in thiis, mine has had an aftermarket timer fitted I think, It has a red led and an adjustment for post timing.
The NR (yellow) wire had a poorly fitted large size spade connector, and had been getting hot, came off in my hands. The circuit has a pump, so 1997 on, but must include HDI extras there. Maybe also the 'all or nothing EGR valve' dont know what that would do. I appreciate the image, Uberderv and if you have more related to my 1999 XUDT would be great to have stored in flash while travelling. Cheers, Ronald
13-01-2019, 03:49 PM
Maybe this is for the Lucas system. I'll see what else is n the book.
I see 14 is an advance corrector relay, so maybe the pump unit /is/ the mechanical injection pump after all. I dont have my 306 nearby to check, but I can recall extra wires going to the engine injection pump, compared to my old 405's. Quite a bit of extra complexity there. I guess it is possible that some xud 306 had more emissions stuff fitted for other countries also.
Edit: Yes, I found by google mention that the advance mechanism is for lucas pumps. I will attach the equivalent diagram for a 405, and it has an advance relay too. Interesting how the tacho sensor is referred to as a TDC sensor, maybe this could be used staticly to find top dead centre for no 1 (or 4 ). Ronald |
| Glow plug Amps | Daniel306 | 18 | 11,067 |
17-12-2014, 01:32 PM Last Post: darrenjlobb |
| rounded off glow plug | Chris_90 | 22 | 13,571 |
08-12-2014, 08:10 AM Last Post: Chris_90 |
| Glow plug light issue | Gaz85 | 1 | 2,351 |
30-12-2013, 07:36 PM Last Post: Gaz85 |
